Why does my oil cap blow off?
Dec 12, 2008 | 08:43 AM
I have a chrome rocker cover, with a chrome oil cap. Should there be a kind of gasket/ rubber thinggy on there to keep the cap on? I was driving yesterday with no bonnet on (private road) and I could see the cap blow off!
Dec 12, 2008 | 09:12 AM
Blocked breather
Try cleaning the breather pipes, could be the cap itself, when mine did this i upgraded to a bailey oil breather, it has never done it since
Dec 12, 2008 | 09:19 AM
When you ut the cap on and off the rocker does it have any resistance? If there isn't there should be. A new cap from ford is less than a fiver. If you have checked the cap and that is fine then look at all the breathers and see if they are kinked or bloked. Failing that it could be headgasket or rings. Mine blew off down santa pod and my headgasket went a few miles after lol
Dec 12, 2008 | 09:22 AM
Can't be the head gasket or rings as there new, what breathers do you mean? from the rocker cover?
Dec 12, 2008 | 11:07 AM
Id say it's that chrome oil cap it should have a rubber gasket inside to hold it on. Ive seen them on ebay and alot of them dont have the gasket!!
Dec 12, 2008 | 11:14 AM
Quote:
Originally Posted by
adam.d
how new? have you run it in yet?
Dec 12, 2008 | 11:16 AM
clarke5700
bailey breather kit solved mine
Dec 12, 2008 | 11:17 AM
grayzo
what?
Dec 12, 2008 | 11:23 AM
Won't be ran in yet as I've only done about 2 miles in it! the engine is all brand new
I have a feeling it will be the oil cap being no good
Dec 12, 2008 | 11:56 AM
ive got a chrome rocker cover and a different to standard cap (chrome)and its got a tiny allen bolt to keep it tite
Dec 12, 2008 | 12:01 PM
adam.d
i would try giving it time to bed the rings in for a bit
Dec 12, 2008 | 12:02 PM
try the cheapest thing first breathers and oil cap. If you dont have ford dealers by you halfords sell them.
Dec 12, 2008 | 12:04 PM
Does sound like a blocked breather to me. They run from the Rocker cover to the inlet manifold, sump, and metering unit.
Dec 12, 2008 | 12:37 PM
clarke5700
I agree, you may have excess crankcase compression if the rings havent fully bedded in but yes, by all means check the breathers etc
Dec 12, 2008 | 12:41 PM
That 1 from the right hand side of the rocker is a bit of a ball ache to get off! All clean anyway. I'll try and get a genuine oil cap and try that
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
2000 ,
blow ,
blowing ,
blown ,
blows ,
breather ,
cap ,
engine ,
escort ,
focus ,
ford ,
im ,
oil ,
racing ,
wwould
