Bilstein gr.A front+rear coilovers with RACELOGIC ECU
Old Dec 11, 2008 | 05:25 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Default Bilstein gr.A front+rear coilovers with RACELOGIC ECU
I have for sale here a set of new rear Bilstein group A coilovers with magnesium casing and watercooled bodies. Absolutly the top specs available. These were fitted with stepper motors on the top so you can live adjust them while driving.
I give the RACELOGIC ECU with wiring loom, plugs, pod and leds.
Obviously not for cruising in the streets hehe. You will have however to wire the shocks to the RACELOGIC loom and setup it with the shocks I was told.
I am open to serious offers for the lot. Considering the shocks are new, top specs (magnesium and watercooled bodies, stepper motors) and there is the full RACELOGIC system included.
Old Dec 13, 2008 | 09:59 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Also for sale :
A pair of front new Bilstein coilovers. Not the normal "group A" version with 41mm. These are pure group A 50mm, to fit std hubs, so a mix between group A and N. They also have watercooled bodies, like the rear ones. These are really new, ready to fit !
I can make discount price if the pair of front and rear are taken at the same time !
Open to offers anyway.
Old Jan 3, 2009 | 01:51 PM
Moonshine's Avatar
Moonshine
Hiya mate, where are the stepper motors? Also, do you know if the these actually work - as in, you've seen them wired up working with the racelogic ECU? What happens if you don't wire it all up, and just stick them on your car - the fronts are just 'normal' in this respect, yes? Finally, give us a ball park figure, mate, I wouldn't want to offend unknowingly!! ( knowingly is a totally different matter! )
Old Jan 7, 2009 | 08:13 AM
Spotmatic's Avatar
Spotmatic
I've send you a PM.
Old Jan 7, 2009 | 08:54 AM
D700 OMB's Avatar
D700 OMB
Its standard!!
Nice bit of kit there. Can you tell me if they are 2wd or 4wd fitment and a rough guide on how much your after for the whole setup.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
IainRS1700T
Sep 25, 2015 06:44 AM
CrOwSoN15
Sep 24, 2015 01:36 PM
DixieTheKid
Sep 14, 2015 09:04 PM
