how can i tell? pic added
Old Dec 8, 2008 | 06:24 PM
ricky_2006's Avatar
ricky_2006
Default how can i tell? pic added
how can i tell without actually takin it off which i cant be fuked to do to see WHICH TURBO i have. i brought s2 few weeks bk. he wasnt 100% which turbo it was. defo a bigger one but he sed maybe a T4. i dnt think it is. thinkin more like a t34.
Old Dec 8, 2008 | 06:32 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
T4 is FOOKING HUGE!bit of a waste on a RST,put a pic up
bezo's Avatar
bezo
powered by K26
take some pics so people can see it and get a better idea.
Old Dec 8, 2008 | 06:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i was just thinking that! !
BIG LAG!!
Old Dec 8, 2008 | 06:34 PM
ricky_2006's Avatar
ricky_2006
i will take pic when i can. i know, i rekon maybe t34
Old Dec 8, 2008 | 06:38 PM
bezo's Avatar
bezo
powered by K26
you realy couldnt miss a T4 under the bonnet of an S2!
Old Dec 17, 2008 | 06:03 PM
ricky_2006's Avatar
ricky_2006
sorry if picture is shit, will try get the turbo properly. will try get anuva one and read wot it actually says on it. it just says GARRETT with sum numbers on it. will look agen 2moz
Old Dec 17, 2008 | 06:07 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
looks like a standard t3 from the pics
take the boost pipe off and take some pics of the compressor housing
Old Dec 17, 2008 | 06:09 PM
ricky_2006's Avatar
ricky_2006
the geezer i brought it off rekons its a bigger turbo?
Old Dec 17, 2008 | 06:11 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I reckon thats a T3. At most it will be Stage 3, the only way you'll know that is to check Turbine housing size, which will probably mean taking the turbo off. It's not a T4 and I'm fairly sure its not a T34.
Old Dec 17, 2008 | 06:13 PM
RST_Rob's Avatar
RST_Rob
cant be 100% but looks the same as my stage 3 from turbotechnics, but hard to tell from pics without seeing it in the flesh so to speak.
Old Dec 17, 2008 | 06:17 PM
ricky_2006's Avatar
ricky_2006
wot would be difference if it was from a standard t3 or stage 3 from turbotechnic
Old Dec 17, 2008 | 06:24 PM
G2RSR's Avatar
G2RSR
Bodybuilding
stage 3 compared to a standard t3 = bigger compressor wheel and the .48 exhaust housing
like i said take the boost pipe off and take a pic of the compressor wheel
Old Dec 17, 2008 | 06:52 PM
gus's Avatar
gus
i would disagree
Old Dec 17, 2008 | 06:54 PM
gus's Avatar
gus
you wouldnt see mine when fitted
Old Dec 18, 2008 | 04:39 PM
blueskies85's Avatar
blueskies85
definately not its bigger than an adult bulldogs head
Old Dec 18, 2008 | 05:14 PM
crazycage's Avatar
crazycage
your turbo is under your inlet isn't it? whats the thinking behind it if you don't mind me asking.
Old Dec 18, 2008 | 05:56 PM
gus's Avatar
gus
the manifold was designed by ava for shed loads of torque
and it works
other advantages are that i can now run a nice size rad / intercooler without the comp housing putting hole in rad
Old Dec 19, 2008 | 09:43 PM
bezo's Avatar
bezo
powered by K26
i would disagree
well on yours maybe. but if it was bolted up in the normal way then you couldnt miss a t4.
my kkk26 you cant miss, the cooler is almost through the bumper
Pwrs2k
23
Sep 26, 2015 09:45 AM
