So does Rod now have the most torque ever from a YB engine?
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Didn't Jenspeed claim 720ftlb?
Awesome result from M.A.D.
Congratulations Rod
Im not convinced the scandy bhp and lbft readings are the same as uk ones, every engine julian sends over there seems to gain about 100bhp on the ferry
Very nice results, i was reading my quartly mag from MLR earlier, and couldn't believe Si Norris' Evo, didn't his make 930 ft/lbs on that dyno? That Crazy torque.
Gaining 300bhp in 500rpm must be interesting in a RWD
Was the torque capped at all, or is that just how the graph is plotted?
Can you confirm the valves are standard sized? Any idea what CFM the head flows, or is that asking too much
:thumpsup:
Yes valves are standard size & ports smaller than they could be to keep the drivability. Im not sure what this engine could make with a wilder ex cam & bigger head but I heard 920bhp mentioned but with a loss of all the good bits on that graph low down, IM MEGA HAPPY WITH THIS ENGINE
So the 47hp increase for the inlet manifold added onto the 750 shown on the old graph would be around 800 bhp..........nice, or have I got that wrong?
Does 40hp sound about right between 99 and 109 fuel?
Mark said that it was likely to have made 770/780 on pump but its of little interest as 750 is more than enough on the road & ive always got the Nitrous button if I meet a more obstinate challenger .
My dad is only 6 years older than you Rod, he's a Cosworth nut and enjoyed 150mph topspeed runs on early Sunday mornings exactly 20 years ago when he first bought his Saph', he's been very content with 300hp for the last 10 years, you are nuts mate.........
The thought of using a GT42 (or bigger) a couple of years ago for a "road" engine was hilarious and not to be taken seriously, to pull it off is amazing.
750 on pump fuel with a torque curve like that is just ridiculous.......rock on
For what you and Mark have both achieved, I think is fantastic, well done.
Chip, is measuring the combined area under both power and torque curves a fairer way to compare all types of engines?
You only really need to use bhp, as it is calculated from the torque anyway, basically the more area under the graph the better
On rods engine for example. You could stay above 600 ft/lbs through the gears in rod's engine, but it'd be faster to change later than that, where you might managed to keep above 800bhp
No nitrous system was plumbed in on the dyno mate, the plan is to use that in the car on the rollers.
It would have turned the dyno session into a 2 day affair to try and use the nitrous there too realistically.
