Faulty speedo on focus?
Wondering if any ones had a problem with a speeedo on a T reg focus 1.4 zetec?. Can be driving along an the speedo and milleage just stops working then comes back on when it wants.
yeah more than likely the vehicle speed sensor is faulty although theres a possibility that the dash cluster itself has packed up.needs checking out to see if theres a code set for vss
probably the clocks themselves
they go all the time, very common
there was even a feature on watchdog about it a while back
all the stupid cunts with a 8 year old focus were wanting it recalled and done for nothing
needless to say ford told them where to go
if its the clocks i can supply you the internals to a focus clocks, basicly remove the dials, take back off takes two secs, and pull off board and replace, i can also supply it to any mileage required.
not a add by the way its just something i can actually advice on and offer for once on here lol
lol ill vouch for that.if you get a good one they come right out.if you dont then its drilling down the centre with a long self taper through middle it is.can be a right arsebag to get out
