whats the difference between 4x4 and 2wd front hubs
formerly beefy-rst-2
as above , is there any eaisily spottable visual differences between a 4x4 and 2wd hub ,
and before you say a drive shaft ,
the car in questions been converted to 2wd ,
just trying to acertain if they used diff hubs or left on the 4x4
thanks beef
thanks beef
it is different mate but easiest way to tell is the back of the hub and the front
if it has a big nut in the middle its 4x4 if it looks like a nut but is around 3" across and nothing in the middle its 2wd
lol that didnt make sense to me jack lol
i kinda know what your saying , but thats hard to put across to a third party
beef
On a 2wd the big nut holding the hub faces on, is on the inside face of the hub, and ona 4x4 its on the outer side.
To convert a 4x4 to 2wd people just take the shaft out of the outer cv and leave its body in place to hold the hub together
the 4x4 one has a nut holding the shaft in it even if its dummied the 2wd has nothing in the middle and looks like an internal type nut sort of like you would use the worlds biggest allen key to undo it
2wd = http://i21.ebayimg.com/06/i/001/20/32/9394_2.JPG
4wd = http://i20.ebayimg.com/06/i/001/17/24/b1c7_1.JPG
only with a nut in the middle if it's on a car.
The easy way is hole size for the strut is larger on 4wd, and the area of the hub at the base of the strut is solid on 4wd whereas it is sculpted away on 2wd, as you look with disc facing flat at you.
2wd calipers can be used with xr4x4 hubs so not always a dead giveaway
also the hubs are differant where the ball joint goes in
4x4 have a pinch bolt, 2wd has nut on top of ball joint i'm sure
lol not trying to do anything dan mate ,
just speaking to a chap who has some brakes for sale thats all,
the car was converted to 2wd , but he wasnt 100% sure if the front hubs had been swapped ,
on further investigaton it looks like they have
so im having them
beef
so im having them
beef
jason_nike
Aug 18, 2019 10:53 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
