Saph Recaro seat mounting dimensions
Morning dudes,
Does anyone have a Saph Recaro seat to hand that they could measure for me please?
I just need to know the base mounting dimensions with all bolt holes to sort some subframes.
If anyone could help, I would really appreciate it
Thanks
Weeksy
Thanks
Weeksy
I really don't know if the sapph ones are different the Escort / Fezzie ones?
I thought Saph ones were wider, are that just above the mounting they are bigger!?
The mounting dimensions of the seat itself, rather than the subframe.
If it's not too much trouble fella, that would be magic
Thanks
Weeksy
Thanks
Weeksy
Thanks
Weeksy
Thanks
Weeksy
yup centre to centre. there's 2 bolt hole's at the front. the 2nd one in is 25mm back from the first one. and at the back there's the runner bolt hole and just a hole in the metal on the seat frame also 25mm back.
hope this is making sense..lol
the bolt hole's for the runner's are 365mm between centre's. and there is a seperate hole 25mm back from the front most runner hole. would a couple of pic's help m8?
the front of the seat is the bottom of the picture.
the front most hole is where the runner bolt's on. the next bolt hole up is 25mm away. then on the same side the other runner bolt hole is 365mm then the hole above that is 25mm away again. and the width is 370mm.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
base, bolt, dimension, dimensions, focus, ford, hole, installation, measurement, mount, mounting, recaro, seat, size, width
