fiesta turbo mixture
Old Nov 30, 2008 | 03:17 PM
ADT168's Avatar
ADT168
Default fiesta turbo mixture
does anyone know were the screw is to adjust the mixture on a fiesta turbo efi. ofab. car
any pictures would help.
thanks regards ashley
Old Nov 30, 2008 | 03:20 PM
stembo21's Avatar
stembo21
ther is a little sensor next to the map sensor with a screw on it called a co pot that is your mixture screw mate it is ner the inlet i ant got any pics of one
Old Nov 30, 2008 | 03:21 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The CO pot only adjusts the idle mixture though, you can't adjust 'the mixture' as a whole, well not unless you're remapping it or being cowboy with the fuel pressure
Old Nov 30, 2008 | 03:23 PM
ADT168's Avatar
ADT168
the reason i ask this. is because the spark plugs are sooty black and stink of fuel.
Old Nov 30, 2008 | 03:24 PM
stembo21's Avatar
stembo21
i know but all he wanted to know is were it was
here is a pic of one
https://secure.encryptedspace.com/au...roduct_235.jpg
Old Nov 30, 2008 | 03:27 PM
ADT168's Avatar
ADT168
thanks m8.
Old Nov 30, 2008 | 03:43 PM
stembo21's Avatar
stembo21
Originally Posted by ashleyt
thanks m8.
your welcome
Old Nov 30, 2008 | 03:46 PM
BigPeBe's Avatar
BigPeBe
Yeah, on "normal" EFi systems like this you can't really properly adjust the mixture.
Adjusting the screw mentioned above will only have a real effect on idle mixture, if you're running too rich the problem probably is somewhere else.
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
turbobill
Aug 1, 2015 08:55 PM
