Toad remote battery
Old Nov 30, 2008 | 01:11 PM
BM08's Avatar
BM08
Default Toad remote battery
Does anyone know if the battery in a toad ai606 remote would be the same size as a clifford concept 300 remote battery?
Old Nov 30, 2008 | 03:02 PM
I don't know what the cliiford takes, but toad are 2032, as I just looked, it might help
Old Nov 30, 2008 | 03:04 PM
BM08's Avatar
BM08
Cheers. ive got a clifford concept battery here you see, which is a CR2032 aswell, so ill keep that incase i need it for my currant toad alarm
Old Nov 30, 2008 | 03:10 PM
Madbradz's Avatar
Madbradz
Open it and see it it fits... Not rocket science is it....
Old Nov 30, 2008 | 03:23 PM
BM08's Avatar
BM08
Its a tight fit, last time i opened one it broke the circuit board inside and i had to solder it back together, thats why im asking instead
Old Nov 30, 2008 | 04:22 PM
You'll be fine with the toad fobs, just use a spoon to prise in the gap near the ring/slot at bottom right corner if facing you, then the inner bit board and battery just pops out in a silicone moulding, take out board, use a small pointed bit to prise/slide battery out, reverse procedure.
It would be pretty hard to accidentally break a toad one, I've never broke one in over 10 years.
Old Nov 30, 2008 | 04:36 PM
BM08's Avatar
BM08
The one i broke by simply opening it was a clifford, all i did was pop it off and the circuit board come out in my hand
Thanks tabetha
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
