heat wrapping
Old Nov 29, 2008 | 01:58 PM
Bullett's Avatar
Bullett
Default heat wrapping
is it any benefit to heat wrap the down pipe and front section of the exhaust on a 4x4 cossie?
thought about doing to mine while its off but wasnt sure. also is it true that if you wrap the manifolds they crack? this is the biggest reason i havent bothered with the stuff but wasnt sure if its correct or not.
i know there is obvious drops in temps after doing the manifold but are you doing more damage by it cracking and blowing rather than a bit of heat?
Old Nov 29, 2008 | 08:53 PM
It is not going to make it crack.
Old Nov 30, 2008 | 08:38 AM
Bullett's Avatar
Bullett
thats cool,what about the downpipe and front section?worth doing?
Old Nov 30, 2008 | 08:42 AM
orionmojo's Avatar
orionmojo
i've heard all different sotries about cracking etc also. but on my rst its been fine so far, and with me running a standard bonnet, it also makes quite a difference. i was told that if you wrap the exhaust it makes it pop and flame out of the back more. if this is true, i'm gonna do mine just for that reason
Old Nov 30, 2008 | 08:54 AM
Bullett's Avatar
Bullett
lol,child.
i just thopught while mine was off it may be worth doing to keep temps at the back of the bay down.i can feel alot of heat through the trans tunnel as it is so must be high down that part of the bay
Old Nov 30, 2008 | 09:22 AM
orionmojo's Avatar
orionmojo
you've gotta have some perks flamer kits are gay, but flames on a gearchange are cool.
well like i said i run a standard bonnet on my orion still and the underbonnet temps are really good. compared to my mates' rst's with vented bonets and non wrapped manifolds theres still a difference.
Old Nov 30, 2008 | 01:58 PM
steven mc kay's Avatar
steven mc kay
Default hello
i had my exhaust off a while back and i did the down pipe only it deff helped keep the temps down a little..
Old Nov 30, 2008 | 02:43 PM
Bullett's Avatar
Bullett
cool.what make did you use?or was just the cheap rolls you can get most places?
Old Nov 30, 2008 | 02:46 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Will be fine, Mike R and a few others have theres wrapped.
How is the Escos?
Old Nov 30, 2008 | 02:50 PM
steven mc kay
Default hi
i got mine off mike r mate cant remember the make of it ..
Old Nov 30, 2008 | 02:52 PM
steven mc kay
Default coated
How is the Escos?
i think mike r has his coated with ceramic coating now its the best way to do it but a lot more dosh..
Old Nov 30, 2008 | 02:54 PM
Bullett's Avatar
Bullett
How is the Escos?
still hunting radders,turbo was sent off but its fine.got to check exhaust next.then its off to martoon
Old Nov 30, 2008 | 04:49 PM
DaveZS's Avatar
DaveZS
Better use my strong hand
Wear gloves when you put it on, made my arms itchy as fuck
Old Nov 30, 2008 | 04:51 PM
MAD EVO 4's Avatar
MAD EVO 4
Ive seen exhaust systems crack including manifolds , we only ceramic coat our systems as this has proven to us to be alot better
Old Nov 30, 2008 | 04:57 PM
orionmojo's Avatar
orionmojo
performance ford did an interesting test last month. there are pro's and cons to both ways
Old Nov 30, 2008 | 05:04 PM
Its Dave's Avatar
Its Dave
Neil, get them coated
Speak to Zircotec, they did my down pipe
http://www.zircotec.com/
Old Nov 30, 2008 | 05:09 PM
Bullett's Avatar
Bullett
dave, i know thats the best way and i will probaly go that way at a later date but im still having to spend money sorting other bits and im skint.so thought wrapping the down pipe would be a good idea as its cheap for now.
on a side note,mad evo 4. how has a stainless exhaust cracked due to it? never heard of that and didnt think it would.
Old Nov 30, 2008 | 06:01 PM
Charlie Chalk
Unknown.
Shame Neil, No news on the issue then?
If you heat wrap it, soak it in water first, helps keep the fibres together and you wont itch
Old Nov 30, 2008 | 06:05 PM
Bullett's Avatar
Bullett
nah not at the mo.want it done before next years show for certain.as its annpying me now.
think im going to hold out on the wrap till i can afford coating.
Old Nov 30, 2008 | 06:09 PM
KSA-Cossie's Avatar
KSA-Cossie
I heatwrapped mine down past the front diff.
Old Nov 30, 2008 | 06:12 PM
Its Dave's Avatar
Its Dave
l had 2 parts done, one bit in picture and the other part is about the same length and it came to Ł220 and they turned it around in 3 days
KW-rscos's Avatar
KW-rscos
What sort of price would it be to do a zetec 4-brance manifold?
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Fordmad!
Sep 29, 2015 07:03 PM
cossie09
Sep 10, 2015 06:56 PM
