higher torque starter motor????????
Old Nov 26, 2008 | 05:54 PM
ricky_2006's Avatar
ricky_2006
Default higher torque starter motor????????
brought a escort s2 on sunday. MINT. has been bored out to a 1.9. stuggles to bludy start, so annoying. when running the engine is sweet as a nut.
battery went flat and when RAC man came and jumpstarted it, it still took longer to start. drove it for atleast 45mins. left it for a few hours and tried it agen. SAME THING, struggled to start
think it might need a high torque starter motor.
eny suggestions or what starter motor i could use.
Old Nov 26, 2008 | 06:12 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
You 100% sure the alternator and battery are working fine?? and that theres no electrical problems taking your juice???
Old Nov 26, 2008 | 06:39 PM
ballin's Avatar
ballin
I very much doubt you need a starter motor with more torque, I would have thought compression ratio would determine torque required, not engine size.
Old Nov 26, 2008 | 06:40 PM
ricky_2006's Avatar
ricky_2006
not 100%, gna fully charge it 2nite.
thats otha thing i was thinking of but its got descent battery. it does have an alarm and sounds. but with a good battery then that shouldnt drain it really.
cnt fink of enything else electrical problem?????
Old Nov 26, 2008 | 06:43 PM
ricky_2006's Avatar
ricky_2006
well i know a family who builds engines.
they bore out a 2.0l pinto engine i think to a 2.2-2.3l and they need higher torque starter motor to fire it up.
so????
Old Nov 26, 2008 | 06:44 PM
Psycho Warren
Carbon Crazy
use your multimeter to check it out.
Also use it to test the alternator charging as well.
How old is the starter?? could just be getting old/cooked too much etc
haz87's Avatar
haz87
Could just be an old/overheated motor. Happens on alot of S2's
Psycho Warren
Carbon Crazy
Old Nov 26, 2008 | 06:45 PM
Psycho Warren
Carbon Crazy
whooooaaaaaa my double post was split!!!!
ricky_2006's Avatar
ricky_2006
my multimeter????????
Old Nov 26, 2008 | 06:46 PM
biglee's Avatar
biglee
Audio specialist
i would check all the connections and clean them up and just make sure everything is getting ample current blah blah.
ricky_2006's Avatar
ricky_2006
i dout it lol. i take a pic of it and show if u want.
engine has onli done 3000 miles.
when its started up, it sounds fucking sweet as
Old Nov 26, 2008 | 06:47 PM
Psycho Warren
Carbon Crazy
you have got one then??
They are a very useful tool to help diagnose electrical issues on cars.
Old Nov 26, 2008 | 06:48 PM
Psycho Warren
Carbon Crazy
Old Nov 26, 2008 | 06:49 PM
ricky_2006's Avatar
ricky_2006
no lol, but i know sum1 with one so i will get them to check out
Psycho Warren
Carbon Crazy
You can cook starter motors quite easily even if new. Done that to a crappy cheap starter fitted to my rs1800 within a few months.
Old Nov 26, 2008 | 06:53 PM
ricky_2006's Avatar
ricky_2006
could be the timing needs adjusting. aargrgrgrrrr. apart from that, the engine is soooo nice and sounds the nuts when started lol
im taking it to torque of the devil on 19th dec for propa tune so hopefully they can have an idea
Old Nov 26, 2008 | 06:56 PM
Jim Galbally's Avatar
Jim Galbally
youve described a fucked battery, what makes you think there's nothing wrong with the battery?
Old Nov 26, 2008 | 06:57 PM
Jim Galbally
oh and describe "struggles"...
turns over slowly? (what i was talking about with the battery)
turns over fine but wont fire? (non-starter related fault)
Old Nov 26, 2008 | 06:58 PM
Psycho Warren
Carbon Crazy
What makes you think its the timing causing your issues???
Old Nov 26, 2008 | 06:59 PM
ricky_2006's Avatar
ricky_2006
well im not 100% mate, just thinking of the worst tbh.
but even when sum put a jump pack on it, it sparked fine etc but took like 5 seconds to actually start.
Old Nov 26, 2008 | 07:01 PM
ricky_2006's Avatar
ricky_2006
just wot sum1 sed?
Old Nov 26, 2008 | 07:05 PM
Rossco's Avatar
Rossco
so????
Yep and the Pinto proberly runs 12-13:1 compression ratio where as your RS will be around 9:1, or lower. Dont waste your money on a high touque starter.
Old Nov 26, 2008 | 07:06 PM
BigChuck's Avatar
BigChuck
i would stick a new battery in it.
Old Nov 26, 2008 | 07:10 PM
ricky_2006's Avatar
ricky_2006
prob gna do that mate. just a descent one from halfords or sumin????
Old Nov 26, 2008 | 07:12 PM
BigChuck's Avatar
BigChuck
any motor factors should be able to sort you out.
Old Nov 26, 2008 | 07:48 PM
haz87's Avatar
haz87
Just cause the starter looks good from the outside doesn't tell you anything about the internals...
Old Nov 26, 2008 | 10:44 PM
Jim Galbally
please answer my question as it's actually rather relevant
Old Nov 27, 2008 | 06:29 AM
The engine may still be tight ?, I have seen this a lot, on modded cars, where starting is ok till an engine change then extra urge needed for new engine is the last straw, and slowly gives up, had it on my dads xr4i, when we changed 3.5 for 4l, as 4l was new and tight same thing.
I would first though clean up all connections, then check charge rate, do discharge test on battery, it may just need new brushes or a clean out of the starter, but as said these are famous for cooking starters.
If it was ignition it would tend to kick back when turning on starter, and pink as well once started, but only a strobe light away from fixing, if that, which I don't think it is.
Old Nov 27, 2008 | 05:54 PM
ricky_2006's Avatar
ricky_2006
one of the cells is low.
need a new battery.
looking for over 560A but needs to be square terminal.
halfords didnt have it, gna go euro parts 2moro
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
DavidK
Sep 27, 2015 02:55 PM
marky_g
Sep 12, 2015 04:26 PM
