Any hilti reps or other fast fixing system reps
need info on hilti/spit type cartridge fixing guns etc
mainly for fixings into concrete/steel with hilti/spit type nails.
been to the hilti site but its vague
Lee
Lee
i needed a part for my hilti drill, £5 odds but they bumped it up to nearly £15 by the time they added a minimum balance handling fee. who adds bullshit charges like that nowadays apart from hilti?
I used to use them about 40 years ago, have you seen a nail go into an RSJ in one hit?
http://www.hilti.co.uk/holuk/modules...jsp?OID=-27919
http://www.hilti.co.uk/holuk/modules...jsp?OID=-27424
steve i need to fix a flat piece of metal to concrete , but the metal has a hole in it which the nail must go through but then fix the strip of metal to the concrete.
i'll get a pick up in a sec exactly of what i need to fix.
right need to fix this to concrete and there is a little requirement.
the nail point should protrude out of the gun in order for me to put this strip over the nail before i fix it . ensuring the nail goes through the hole.
not like mf stud where the nail just fires anywhere through the tin and fixes it.
also need a tool with as long as poss extention to so i can reach the slab with out needing higher access tower/steps etc.
big ask i know!
big ask i know!
i use then most days mate! if you get the correct fixings it will do wat you want easy! but if your planning on using it on a big site bovis, langs ect you will need a license mate.
From: Dewsbury, The parts were they don't abduct their own children!
Where abouts are you based? I could get you our hilti reps phone number from work but he will deal in the northwest area?
Also hilti and spitt both do gun extensions so that you can use the gun up to 2-3 metres. We use them at work to shotfire to eiling slabs through lay-in grid ceilings.
Aslo once you have found the correct shot fixing to suit the 'all round' band that you need to fix. The depth of the nail will all depend on the power of the cartridge and the settings on the gun itself.
Hilti/spitt will explain this, but you may have to pay them to train you to use the guns safety/correctly?
Russ Payne
Sep 25, 2015 08:29 PM
