Chip - comp ratio quick question
Old Nov 26, 2008 | 04:00 PM
BRAMMER's Avatar
BRAMMER
Default Chip - comp ratio quick question
Quicky
Will a chip that's mapped for low comp work on a engine that's has the same turbo, injectors etc just diff comp ratio ????
Old Nov 26, 2008 | 04:02 PM
rst in breaking's Avatar
rst in breaking
id imagine it would fuel wrong at a gues?
Old Nov 26, 2008 | 04:15 PM
BRAMMER's Avatar
BRAMMER
cheers
Can anyone be 100%
Old Nov 26, 2008 | 04:18 PM
AlexF's Avatar
AlexF
It wont be right - your CR will effect the amount/rate of energy released into the exh and so effect the way your turbo spools....
Its mainly your ignition timing that changes with CR changes... roughly speaking.
rst in breaking
actually saying that id imagine it would as when chip was mapping mine the the compression ratio affected what ignition timimg or something he could give the engine i think
Old Nov 26, 2008 | 04:19 PM
Jim Galbally's Avatar
Jim Galbally
ditto alex.
the car will start and drive but it wont be right
Old Nov 26, 2008 | 04:25 PM
BRAMMER's Avatar
BRAMMER
Right cheers for that
Old Nov 26, 2008 | 04:28 PM
Stu @ M Developments's Avatar
PassionFords Creator
Will run quite well.
Spark table will be wrong as would the fuel but to a much lesser extent.
How wrong the tables will be depends on which way you went. Goin higher CR would usually be deadly.
Old Nov 26, 2008 | 05:16 PM
BRAMMER's Avatar
BRAMMER
Well the comp ration is standard so it's no use??
Old Nov 26, 2008 | 05:17 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
DONT drive it then if the map is for lower CR than you have.
Old Nov 26, 2008 | 05:19 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
if the chip is low comp, and your engine is std, then bin it!
Old Nov 26, 2008 | 05:28 PM
Chip's Avatar
Chip
It might be that you can get it to run safely using the octane wires by the way, if this is for an L8 or other ecu that has them, but its still going to be far from ideal.
Old Nov 26, 2008 | 05:49 PM
BRAMMER's Avatar
BRAMMER
No problem it was a chip in an ECU interested in buying and this was the only factor that was different from my spec.
Old Nov 26, 2008 | 05:55 PM
Benni's Avatar
Benni
Ban[B][/B]ned
That's unlucky.
Benni.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSmark84
Sep 13, 2015 01:29 PM
Bransby
Sep 11, 2015 01:09 AM
