Mk1 escort 4x4 cosworth
Old Nov 25, 2008 | 10:46 PM
mk1escoz4x4's Avatar
mk1escoz4x4
Default Mk1 escort 4x4 cosworth
ALL WORK TO BE CARRIED OUT BY IAN AT THE RS CENTRE AND TOMMY FIELD MOTORSPORT
Engine
Pectal Super 8 ECU
Cosworth YB 200 Long Stud Block
Fully Flow Ported Head
Lightened And Ballanced Crank
Shot Peaned Con Rods
Acrolight Custom Dish Pistons
Group A Head Gasket
ARP Big End Bolts
Modified High Pressure Oil Pump
BD 16 Inlet Cams
BD10 Exhaust Cams
Upgraded Valve Springs
Upgraded Hydraulic Tapets
RS500 Spec 8 Injector Inlet Manifold
72mm Billit Inlet Butterfly
8 Green Injectors
Group A Ignition Coil
Air Injection
19 Row Oil Cooler
Custom Water Injection
4x Bosh 044 fuel Pumps
Plus 2x Bosh Fuel Filters
Pro Alloy Baffled Fuel Tank With Full Filler Neck and Pro Alloy Flush Fit Filler Cap
GT30 Turbo running a tial external waste gate
Baily alloy tanks througout
All high pressure lines are stainless braded with goodridge fittings
Cirrus Heat shielding
Blue high performance silicone hoses throughout engine bay
Stainless 2 1/2 inch Powerflow custom exhaust system
Transmission
Quaife Front Diff
Quaife Rear Diff
4WD MT75 5 Speed Dog Engagement Quaife Gearbox
with B&m Short shift gear leaver
Ap racing 6 paddle cluch
Lightened and balenced flywheel
Group A Mounts
Suspension
Gaz gold adjustable coil overs
modified rear beam and arms
Adjustable TCA's
Compression Struts
Ajustable top mounts
Brakes
AP racing 4 pot calipers
330mm Front disks
300mm Rear disks
Custom rally pedal box
Bias control
Braded hoses
Goodridge fittings
Wheels
8x18" white motorsport revolutions
245/40/18 dunlop sport tyres
Interior
Carbon Fiber inserts throughout
Full Multipoint Welded in roll cage
(consists of Cross door bars, cross diagonals, Tunnel brace, harness tubes, triangulation tubes to front struts)
Cobra Monaco Bucket seats
Luke 6 Point Harnesses Fitted with rotary action release
On dash Splitfire tachometer with Shift light
Turbo Boost Guage up to 35 PSI
Battery isolator
Digi Stack Dash with ( Speed, Rpm, Water Temp, Oil Pressure, Oil temp, Volt meter, Fuel Level and gear engagement)
Standard 4wd Cosworth Steering wheel
Navigators foot rest
Switch Panel with motorsport Toggle Switches
Bodywork
MK 1 Escort Shell
Fully Restored
With New Floors Sills Etc
Fully welded and strenghened
Body shell also modified to accept 4x4 running gear
Air vented Modified front panel
Also air vented inner wings
all metal bubble arches
with widened rear quarters
Motorsport bonnet pins
Full respray including, engine bay, inside and outside also fully undersealed
Standard Mk1 chrome handles, wing mirrors. Rs 2000 black powdercoated bumpers
WE ARE NOW CHANGING THE WIRING LOOM TO A CUSTOM MADE FIREPROOF ONE, UPGRADING TO P8 WITH ANTI LAG, FITTING COIL PACKS, FITTING THE WATER INJECTION, FITTING NOS, MACHINING THE GEARBOX TO TAKE A HYDRAULIC CLUTCH, STRENGTHENING THE FRONT DRIVESHAFTS, FITTING POWER STEERING WITH A RS1600I WHEEL, MOVING THE BATTERY TO THE BOOT, FITTING ALL NEW SWITCHGEAR AND GAUGES, FITTING A LAMINATED FRONT SCREEN, CHANGING THE WHEELS TO ULTRALITE 18X8J'S WITH MICHELIN PILOT SPORT 2 XL'S 225/40/18'S AND A 25 OFFSET TO CLEAR THE REAR SHOCKS AND THE INTERCOOLER MOUNTED UNDER THE FRONT N/S INNER WING, FITTING A HYDRAULIC HANDBRAKE, FABRICATING NEW BRACKETS FOR THE EXHAUST AND GEARBOX, FITTING A REMOTE SERVO, CARBON FIBRE BONNET, ETC ETC ETC I WILL POST MORE AS IT GETS DONE
Old Nov 25, 2008 | 10:48 PM
mad dog younge's Avatar
mad dog younge
Originally Posted by mk1escoz4x4
is that wot you are build mate .looks fucking mint
Old Nov 25, 2008 | 10:49 PM
mk1escoz4x4
Default ap 4 pots on the front and cosworth calipers on the rear
Old Nov 25, 2008 | 10:50 PM
mad dog younge
more pics .under side and engine bay please
Old Nov 25, 2008 | 10:51 PM
mk1escoz4x4
Default hard work never hurt anybody
Old Nov 25, 2008 | 10:54 PM
mk1escoz4x4
Default wheels are being replaced by a set of 18 x 8 j ultralites
Old Nov 25, 2008 | 10:56 PM
mk1escoz4x4
Default cobra monacos with 6 point harnesses
Old Nov 25, 2008 | 11:00 PM
mk1escoz4x4
Default Running 4 x 044 pumps from a pro alloy baffled tank
Old Nov 25, 2008 | 11:35 PM
mk1escoz4x4
havent got the hang of posting pics yet and it wont let me download a lot of the pics i have got, but i will keep plugging away at it mate until i get it sorted
Old Nov 26, 2008 | 12:51 AM
madsi's Avatar
madsi
very nice we like that alot
Old Nov 26, 2008 | 06:49 AM
righthooker's Avatar
righthooker
superb,, will it be out and about any where next year ,,, shows ect???
Old Nov 26, 2008 | 06:50 AM
Oh thats nice
Old Nov 26, 2008 | 06:55 AM
roro22's Avatar
roro22
that is so right
ultimate toy
Old Nov 26, 2008 | 07:04 AM
series1john's Avatar
series1john
Now that is SOOOOOOOOOOOOOOOOOOOOOOOOOOO nice, wish i had time and money to build something like that top job fella
Old Nov 26, 2008 | 07:13 AM
Rossco's Avatar
Rossco
Cracking car, more pics and vids please.
Old Nov 26, 2008 | 08:43 AM
RSLUBBY's Avatar
RSLUBBY
bootifull mate
Old Nov 26, 2008 | 08:46 AM
billynocar's Avatar
billynocar
very jealous
top looking motor fella
Old Nov 26, 2008 | 08:50 AM
SteveH's Avatar
SteveH
Looks cracking mate
Old Nov 26, 2008 | 09:16 AM
MK4 CABI's Avatar
MK4 CABI
Very nice, would love a cossy mk1
Old Nov 26, 2008 | 09:23 AM
marky_g's Avatar
marky_g
Fleet Manager
thats smart, not keen on white wheels on the blue tho but very cool
Old Nov 26, 2008 | 10:29 AM
carlo's Avatar
carlo
Cracking car mate they wheel arches dont do anything for it tho the mk1 bubble arches would make that car perfect
Old Nov 26, 2008 | 11:46 AM
Less.'s Avatar
Less.
having a mid life crisis
Quality car
Old Nov 26, 2008 | 12:48 PM
mk1escoz4x4
Default Thanks for all your comments
ive just joined the site and im only just getting the hang of posting pics ect i will try and get as much info about the car in as possible over the coming weeks and try and work out why the site wont download a lot of my pics any questions i will be happy to answer thank you, matt.
Old Nov 26, 2008 | 12:53 PM
mk1escoz4x4
yes im hoping to have it finished by early january but that probably means march to be honest there is a lot to do to it then im going to get it out on the track and see how quick i can pop the drive shafts and melt the pistons!
Old Nov 26, 2008 | 12:58 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Cossie Mk1 thats the dream, and 4by
Would I of seen this on the bay?
Old Nov 26, 2008 | 01:00 PM
mk1escoz4x4
yes it was on e-bay but it had to be totally ripped apart and started again
Old Nov 26, 2008 | 01:01 PM
mk1escoz4x4
Originally Posted by billynocar
very jealous
you wouldnt be jealous if you had spent what i have mate!
Old Nov 26, 2008 | 01:02 PM
Mark_'s Avatar
Mark_
that looks awsome, and 4x4, wow!
Old Nov 26, 2008 | 01:03 PM
mk1escoz4x4
dont worry those wheels are going and being replaced with a set of 18" x 8j ultralites
Old Nov 26, 2008 | 01:05 PM
mk1escoz4x4
thank you for your post and its not finished yet by a long way
Old Nov 26, 2008 | 01:06 PM
mk1escoz4x4
Originally Posted by ED 209
Quality car
thank you
Old Nov 26, 2008 | 01:09 PM
mk1escoz4x4
hopefully when its finished i would like to sacre a few corsas and saxos round where i live
Old Nov 26, 2008 | 01:12 PM
mk1escoz4x4
personally i would have chosen steel bubble arches but they were already on the car when i bought it and they have done a really good job of fitting them so i'll wait until i prang it to change them!
Old Nov 26, 2008 | 01:13 PM
mk1escoz4x4
Originally Posted by SteveH
Looks cracking mate
thank you
Old Nov 26, 2008 | 01:17 PM
mk1escoz4x4
thanks very much long way to go though
Old Nov 26, 2008 | 01:19 PM
mk1escoz4x4
Originally Posted by Twins
Oh thats nice
it will be when its totally emptied my pockets
Old Nov 26, 2008 | 01:21 PM
mk1escoz4x4
thank you just trying to get the hang of downloading some stuff onto this site
Old Nov 26, 2008 | 02:28 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
what a car.awesome mate
Old Nov 26, 2008 | 02:49 PM
B16CVH's Avatar
B16CVH
Think i need to change my undies!
Old Nov 26, 2008 | 05:20 PM
andy escos's Avatar
andy escos
Default great looking car m8
welcome to pf what spec motor you running ?can you put up the spec 4 all the running gear please
heres a link 2 my 4x4mk2 escort
