fuse melted and wanted header tank
Old Nov 25, 2008 | 09:23 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
Default fuse melted and wanted header tank
thought i would double both posts up
1. my cooling fans fuse has melted , and i mean proper melted - right on to the acutally base of the box and destroyed the terminals - any ideas or has this happened in any of your 3drs or saphs.
2. Headtank - must of been posted up a million times - but anyone know were i could source an orginal plastic one, really struggling.
cheers
Ben.
Old Nov 25, 2008 | 09:36 PM
COLEYST200's Avatar
COLEYST200
you need to get in tuch with RYAN CAR LOOMS UK 07919537128
he will make you a loom that dose away with the old fuse box one as its a loom all on its own iv got one on my car as this fult is comen on the 3dr
and the only new header tank you will get are for the escort cosworth they dont have the flowt in them you wont get a new 3dr one
Old Nov 25, 2008 | 09:41 PM
indycos's Avatar
indycos
helooooo!!!
send me a pm with your email address, tried sending you one, but you dont seem to be accepting them
Old Nov 25, 2008 | 09:44 PM
charlie luciano's Avatar
charlie luciano
I posted a link up for a couple of header tanks in your previous post
here https://passionford.com/forum/ford-sierra-sapphire-rs500-cosworth/269351-header-tank.html
too late now though, bidding has ended
Can't help you with the fuse box though
Luciano
Old Nov 26, 2008 | 08:02 AM
As said std ford wiring is crap, like a lot of the other bits on cossies, a rewire is a piece of piss and a must, can be done in 30 mins making your own loom for around Ł5.
4wd sapphy/escos tanks still available new but not 2wd.
ps a new 4wd tank is Ł34.66p, but ford sell you a new hose(about Ł41) as it has a much larger fitting for the turbo return feed, or you could just make one ?
Old Nov 26, 2008 | 05:32 PM
BAM_S2's Avatar
BAM_S2
D22 BLC
cheers for the reply lads , thats gd help. will try and keep my eye open for one coming up on ebay - as for the fuse - sound advise and will look in to it.
Old Nov 27, 2008 | 01:14 PM
indycos's Avatar
indycos
helooooo!!!
i have a header tank but i cant send you a pm.
moesin2005
Jan 23, 2022 06:28 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
155lee
Aug 14, 2015 11:21 AM
xr_craig
Aug 7, 2015 06:00 PM
adriansaleem
Aug 3, 2015 11:21 AM
