18" O.Z Alloys and tyres + compomotive th 8 x 15
Looking to get rid of these alloys as there taking up too much space in the shed. They are 18" O.Z chronos and have mint tyres.
Looking for 400 quid or sensible offers.
Also have a set of compomotive TH lines in 15 x 8 in a ET25 making them fit like escos wheels only an inch smaller. Come with mint 195/45/15 unfitted as the wheels have just been fully refurbed and powdercoated.
wheels where identical to these but had them powdercoated after laquer started to peel.
Looking for 450 for these.
I contacted you a while ago regarding the OZ's, however I never heard back... What tyres are they? Any pics of the tread depth? And what offset are they?
Thanks
Thanks
the ones in the pic are diamond cut. mine were sent back to dubmeister where i got them from and powdercoated silver as the laquer peeled after a month or so. The wheels are now in the boxes still and have never had tyres since been re done. however i have a full set of 195x45x15 tyres to go with them, cheers
cheers
yeah unfortunatly when i sent them back due to laquer peeling they just powdercoated them silver and sent me them back. They were orginally diamond cut however i wasnt given the choice second time round lol
Ok mate, I was probably looking for a minimim offset of 40, so if you could double check for me what yours are then that would be good. I was also visiting family up near you for a few days when I contacted you last, but now I am about 250 miles away! So if you could let me know the offset of them then we can go from there.
Rich
Rich
Rich
alrite do u definately have the plastic caps there should have 4 round ones for the stud not in use and 4 for the nut for each wheel if u have i will come at weekend and what make ov tyres are on and are there all the same make will you pm me your number
cheers phil
cheers phil
I used to sell these wheels at work and should be ET38 offset if this helps anyone? The wheels are also 7" wide in 4 stud fitment and only 8" wide in 5 stud. I do have some blanking plugs and black plastic covers for the nuts if this also helps.
The width and size is always stamped in the back of all Oz alloys. If you have measured the width you may have got 8" but infact it is 7"
If you also measure the actual wheel size it will measure 19" when infact the wheel is only 18"...The reason for this is that a wheel measurement is taken from where the tyre fits on the beads. If your wheels are 8" wide it will be stamped 8x18. You may be right and I maybe wrong?
