MFI to EFI
Old Nov 24, 2008 | 11:41 PM
RSTurboSI's Avatar
RSTurboSI
Default MFI to EFI
ganna be needing more power soon and toso ill need to convert my RS MFI to EFI
whats the means of going with the progress.
List all parts needed to do the change over and a round about cost when you lot have done a convertion
thanks si
Old Nov 25, 2008 | 12:27 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Loads of options, VEMS, GoTech, Weber L6/L8 or P8, Autronic, Omex...
Do a search for bits etc I'm sure you'll get loads of threads come up
Old Nov 25, 2008 | 12:46 AM
rst in breaking's Avatar
rst in breaking
what kind of power are you after? if keeping your existing engine you will need a adapter plate to use the efi inlet. ofab is prob you best bet on a budget of which you will need to run a efi flywheel and drill your block to accept cps, i wouldnt say its an expensive conversion though tbh £100-150 for ecu and loom, £20 for flywheel (i have one spare) £10 for coil pack, ignition leads (again i have brand new set for sale)
Old Nov 28, 2008 | 03:32 PM
mentalasanything's Avatar
mentalasanything
You dont neccessarily have to use an EFi Flywheel and have a drilled block for the CPS. You could always use the 1.8 Sierra CVH setup which is a toothed bottom pulley and a CPS bracket on the timing belt cover, this is the setup I have ready to fit! List of parts varies but for a simple setup:
EFi Head or MFI>EFI adaptor plate
Complete EFi inlet & Throttle body
ECU and Loom (OFAB/OFAC)
EDIS System
Coilpack & Leads
MAP sensor (ECU Specific)
Sierra CPS setup (inc. Alternator) or Fiesta Turbo CPS setup(inc. Flywheel)
This should get you running but most people go for Beiges and a 195 Chip in with this too.
As I said I will be fitting the Sierra setup as it means I get to keep my original block and I dont have to arse about with flywheels. I have an EFi head and inlet, beiges, OFAC ECU, 195 cihp and OFAC MAP Sensor to fit too. All depends on your future plans and availability of parts, it took me months to find the Sierra CPS setup, but I knew that's the way I wanted to go.
Lee
steve.rst
Mar 15, 2016 08:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
stevierob
Sep 7, 2015 07:09 PM
