Auxilary belt tensioner, cossie
Old Nov 24, 2008 | 09:37 AM
Twellsie's Avatar
Twellsie
Default Auxilary belt tensioner, cossie
changed the auxilary belt at the weekend as it had snapped, all seemed ok untill this morning when i got in the car and had a funny squealing noise which i can only asume its the tensioner, can this part be changed?
I have also noticed after driving and becoming stationary it idles a little higher than usual for a couple of seconds, then drop, any ideas whats causing this as it didnt do it priior to changing the belt.
Old Nov 24, 2008 | 11:41 AM
Twellsie's Avatar
Twellsie
bump
Old Nov 24, 2008 | 05:37 PM
Twellsie's Avatar
Twellsie
someone must know?
Old Nov 24, 2008 | 05:45 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i changed mine a year ago, its around £80 if still available mate
Old Nov 24, 2008 | 05:52 PM
cookiem's Avatar
cookiem
Graham goodes changed my aux belt,when i took my car for service,mine started squealing ,took it back and was told its the belt,quite a common problem they said.i have changed it myself twice since and it still does it,i even changed tensioner,no joy,bought a can of belt dreessing,that stops it squealing.
Old Nov 24, 2008 | 05:54 PM
Twellsie's Avatar
Twellsie
belt dressing?
Old Nov 24, 2008 | 06:10 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
doubt its the tensioner.
most likey poor quality rubber in the belt or even some sort of contamination.
As suggested a belt dressing is often the only cure.
You can get away with using WD40, but its not ideal and wont stop the squeak for long.
proper belt dressing has silicone in it i think. Ive used it lots of times on landrovers, its a common fault when u replace the fan belt on them.
As for the idle issue? only thing related to the belt is its either too loose or tight, cant be any other reason i dont think.
Old Nov 24, 2008 | 06:15 PM
JTECH James
Passion for Fords!
mine was squeaking because the spring in the self tensioner was weak, meaning the belt was slightly loose all the time.....
Old Nov 24, 2008 | 06:18 PM
Twellsie's Avatar
Twellsie
the belt is a proper "Gates" belt, i did manage to spill anti freeze on the old one though, suppose it could be that
Old Nov 24, 2008 | 06:20 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
dont make no difference, even "quality" belts are made of shit rubber these days.
As said check the tension, too loose or too tight will cause a squeak, if not then try some belt dressing.
Old Nov 24, 2008 | 06:23 PM
JTECH James
Passion for Fords!
you cant adjust the tension on late saffs.... if its even slightly slack you need a new tensioner.....
Old Nov 24, 2008 | 06:47 PM
Twellsie's Avatar
Twellsie
it did feel ok when you move it backwards and forwards, it does seem to quiet down as it warms up, if that makes any differance
Old Nov 24, 2008 | 06:48 PM
JTECH James
Passion for Fords!
try some dressing first pal, before forking out for anything....
Old Nov 24, 2008 | 07:02 PM
Twellsie's Avatar
Twellsie
you can get it from Halfrauds i pressume?
Old Nov 24, 2008 | 07:04 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
i have a good used belt if you want to try swoping it.
Old Nov 24, 2008 | 07:05 PM
Lloyd's Avatar
Lloyd
i might also have a tensioner if its on the power steering pump bracket.
Old Nov 24, 2008 | 07:10 PM
Twellsie's Avatar
Twellsie
the tensioner goes directly onto the block iirc, the belt was a brand new one, so would imagine its some crap on the actual pullies if anything.
i'll get some of that belt dressing stuff and go from there, thanks for the offer though LLoyd
Old Nov 24, 2008 | 08:01 PM
JTECH James
Passion for Fords!
tensioner is on the ps bracket....
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
