Bottom End Full Balance
Old Nov 23, 2008 | 08:31 PM
COLEYST200's Avatar
COLEYST200
Default Bottom End Full Balance
hi lads im going to have a full crank regrind fly wheel skimmed and all balanced up at the same time now the thing i need to know is i do remember the place that is going to do the work saying that they need the front pulley crank fly wheel .but will they need the con rods and pistons as well as ive not got the pistons yet as the block has got to be bored out
Old Nov 23, 2008 | 08:34 PM
Tabz @ S.M.Auto's's Avatar
Tabz @ S.M.Auto's
Dont forget your clutch cover.
Old Nov 23, 2008 | 08:35 PM
louie1's Avatar
louie1
the pistons are only weighed on scales along with the rods so should be ok mate
Old Nov 23, 2008 | 08:37 PM
COLEYST200's Avatar
COLEYST200
sorry yes mate they they did say that to .why im asking is i might not tacking the stuff in my self a mate be dropping the stuff of for me
Old Nov 23, 2008 | 08:53 PM
Tabz @ S.M.Auto's
Who is doing it for you, seeing as though your in Birmingham?
Old Nov 23, 2008 | 10:20 PM
COLEYST200's Avatar
COLEYST200
halesowen engines
Old Nov 23, 2008 | 11:30 PM
rst in breaking's Avatar
rst in breaking
when i got mine done they wanted pistons, rings, rods, crank, bottom pulley, flywheel + bolts and clutch + bolts
Old Nov 24, 2008 | 03:22 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
halesowen engines
I use them, top quality service, and the engine will run like a dream once it has been balanced
Old Nov 24, 2008 | 09:54 AM
Anything that moves in the engine that has mass, so pistons are weighted to equalise, ie the lightest one is the one they take meat off the others to make the same as.
Rotational components are vital, as in all of them, rods normally balanced end to end, then as sets for weight, it does make a big difference, always have it done, especially with the titanic weight of cossie flywheels/if they can lighten at same time.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Ben26
Sep 3, 2015 07:55 PM
