Buying a shell with V5 - advice needed
Old Nov 23, 2008 | 05:42 PM
Cam's Avatar
Cam
Default Buying a shell with V5 - advice needed
If I buy, for example, an EsCos shell with V5 that is HPI clear (a car thats been broken not a write off) then fit a different size/type of motor (6.0 V12) midmounted in the shell to a RWD transaxle do I have to have the car inspected or do I just alter the details on the logbook and send it off to the DVLA?
Old Nov 23, 2008 | 05:47 PM
The Youth.'s Avatar
The Youth.
just change the details and ie engine number, capacity etc, and you will get the v5 back all sorted, I did this with my 100E,
If you ask too many questions to them, you may have to go down the points system to keep the id,think you need 8 points to keep the id, 5 for the shell then it's 3 points each for the front and rear axels engine ,trans etc.
so tell them the min they need to know!
steve
Old Nov 23, 2008 | 05:59 PM
Cam's Avatar
Cam
Originally Posted by the youth
just changed the details and ie engine number capacity etc, and you will get the v5 back all sorted, I did this with my 100E,
steve
LOL, Cheers Steve
Treat th DVLA like mushrooms....Keep them in the dark and feed them shit!
Whats the legal standpoint though?
The engine is secondhand, legit with receipt (even has a plaque on it with date it was assembled and name of the guy who built it!)
The gearbox will be brand new
All susp brand new
Secondhand braking system (minty, mint tho)
Rads/coolers/exhaust all new/bespoke
Ideally I want a pre '93 shell so still MOT legal with no CAT.
Old Nov 23, 2008 | 06:37 PM
focusv8's Avatar
focusv8
It should be SVA'd , as it will be a radically altered monocoque which will then result in a Q plate.
But as above just notify engine change and see what happens.
My Focus V.5 says 5000cc as the engine size.
If EITHER the engine or the Shell are pre 93 then no CAT test.
Mine is year 2000 shell with 1988 engine = no CAT test.
.http://www.direct.gov.uk/en/Motoring...le/DG_10014199
Old Nov 24, 2008 | 11:12 AM
Iain Mac's Avatar
Iain Mac
SVA doesn't automatically mean a Q plate - seemingly I'm getting an age-related plate but I used a brand new shell.
In your circumstances I'd just record an engine change.
Old Nov 24, 2008 | 11:16 AM
Rossco's Avatar
Rossco
Hope there is going to be a build thread Cam, sounds like a very intresting project.
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
