does this look right im doin a cambelt on my ecos(small turbo)
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
the rotor arm is facing to 1 isnt it? i can see the dot mark used for static timing on the plastic sheild under the rotor arm....it lines up with the dot on the rotor arm tip.....
reminds me of the time I fitted a new cambelt on my old cossie, rang a 'specialist' to ask about the crank marks and ended up lining it with the wrong one..
sounded quite nice when I fired it up!
Best bit was I'd just changed the tappetts and thought it was those making the noise, no wonder they didn't shut up after 2 miles down the road
Timed it up with the other mark and it soon shut up
So mate you got it all sorted then. I hate doing timing belts on any car never mind my own. Ive heard of people changing the timing belt on cossies without taking the bottom pulley off.
