How high can you safely rev a std YB engine ?
Old Nov 23, 2008 | 09:23 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Default How high can you safely rev a std YB engine ?
With a fully balanced engine, std comp, all pistons/rods same weight, and std cams/lifters, how high can you safely rev a YB engine ? 7000rpm or can you go to 7500rpm ? Turbo is a T34 0.63 and Siemens 55lb injectors.
Any input welcome !
Old Nov 23, 2008 | 09:24 AM
rapidcossie's Avatar
rapidcossie
8k standard quite safely, IF engine is in good condtion
Old Nov 23, 2008 | 09:26 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
7800 imo, you get lifter issues around 8k
Old Nov 23, 2008 | 09:27 AM
BigErn's Avatar
BigErn
low comp with standard everything else, T34 and greys did 8250 ofr a year and a half of total death without any bother.
Old Nov 23, 2008 | 09:28 AM
Jay,'s Avatar
Jay,
Sponsor
wouldnt go no further than 7500 unless u put upraed springs in ! but why it needs to be reved that hard on a t34 is beyond me mate
bud-weis's Avatar
bud-weis
Football Cwazy
I doubt the valve springs would cope with 8k.
Old Nov 23, 2008 | 09:29 AM
Jay,'s Avatar
Jay,
Sponsor
shouldnt get lifter issues on a t34 at that rpm t4 yeas but not a t34
Old Nov 23, 2008 | 09:30 AM
Jay,'s Avatar
Jay,
Sponsor
valve bounce anyone
Old Nov 23, 2008 | 09:31 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Well I have 4.44 diffs and 16" wheels so it would give some more range in the gears to rev it to 7000 or max 7500 rather than 6500. And I think the 0.63 T34 is still good at 7000. Obviously not as good as a T4 of course, but still enough.
Old Nov 23, 2008 | 09:34 AM
Jay,'s Avatar
Jay,
Sponsor
ah ok matt then get some reyland uprated valve springs to be safe and jobs a good one
JTECH James
Passion for Fords!
how does a different turbo change the level of rpm a hydraulic tappet can safely run?
i wouldnt fancy any of my ybs over 7800, without solid lifters
Old Nov 23, 2008 | 09:39 AM
Jay,'s Avatar
Jay,
Sponsor
oh boy did i know this reply was coming
the volume of air is greater plus higher pressure run usually will collapse the hydrohlic tappet hence using solid lifters ! dave (madyum) suffered this issue on his last run at brunters using standard lifters
Old Nov 23, 2008 | 09:42 AM
JTECH James
Passion for Fords!
i assumed you were talking about cam choice, as this also makes a huge difference
Old Nov 23, 2008 | 09:43 AM
Jay,'s Avatar
Jay,
Sponsor
never mentioned cams as he states standard everything hence my reply james
Old Nov 23, 2008 | 09:44 AM
JTECH James
Passion for Fords!
even on a t34 i was loosing power at the end of session on hydraulic tappets at 7500....
Old Nov 23, 2008 | 09:46 AM
JTECH James
Passion for Fords!
but YOU mentioned T4.... and who runs a t4 on std cams?
you said you may get an issue on a t4 but not t34.....maybe thats also due to cam choice?
Old Nov 23, 2008 | 09:51 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
A turbo has no awareness of how fast the engine is turning.. all it knows is airflow..
Mad Matt's Avatar
Mad Matt
Rally nut
With a 0.63 exhaust housing or smaller ?
Old Nov 23, 2008 | 09:53 AM
JTECH James
Passion for Fords!
.48 mate, it was quite noticable...i guess id lost lots of lift
Old Nov 23, 2008 | 09:55 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Yes, but as I have a 0.63, surely there won't be a real major loss ? 0.48 is understandable
Old Nov 23, 2008 | 09:56 AM
Jay,'s Avatar
Jay,
Sponsor
plenty do james as there are those thsat believe a standard cam are good lol
again matt stated standard cams
that turbo will not cause lifter issues's thats why i suggested valve springs
Chip's Avatar
Chip
*** Sierra RS Custard ***
The bottom end will take more revs than there is any point going to on that setup.
Lifters and springs will start to give you issues as you approach the 8K region.
Old Nov 23, 2008 | 09:57 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Yes so will only change the springs then. Good news Will really need these extra rpms. Thanks everyone for the advices
Old Nov 23, 2008 | 10:08 AM
scoooby slayer's Avatar
scoooby slayer
i have uprated springs but oem hyd tappets and 7800 rpm has been no bother.
JTECH James
Passion for Fords!
just be prepared to be disapointed with your power output on hydraulic lifters at the end of a hard session, even more so at high rpm....
imo
scooby slayer, i also run mine at 7800, on hyds...i hope it will be ok,otherwise i willl convert to solids....
Old Nov 23, 2008 | 10:22 AM
Chip's Avatar
Chip
Yeah if you keep it up at those revs it will be rattling its tits off at the end of a track session as the oil thins out, as it will knock the hell out of the lifters.
Old Nov 23, 2008 | 10:33 AM
JTECH James
Passion for Fords!
thats exactly what i found chip.
if you rev it high, you end up loosing so much lift /power,
you may aswell have knocked 500rpm off, and kept it stable, at the end of a session it would have more power, especially on a t34 which makes good low down power
i dont hold out much hope for mine tbh
and nomatter what turbo i would never take hyds over 7800 as you said its more due to heat and oil that causes them issues, they sound like they are empty
Old Nov 23, 2008 | 06:08 PM
col cos1's Avatar
col cos1
my limit is 7800rpm double valve springs and standard lifters
Old Nov 23, 2008 | 06:21 PM
big_wig_074's Avatar
big_wig_074
well at least 500 people started that way!
Old Nov 23, 2008 | 06:24 PM
JTECH James
Passion for Fords!
yes at 200bhp
i dont really see why people would chose a t4 for that
SmudgerByName
52
Jul 28, 2016 06:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
IAN RS2k
Aug 18, 2015 07:51 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Zoggon
Aug 10, 2015 10:39 AM
