Coilover expert garages? London?
Old Nov 22, 2008 | 05:22 PM
cheeky dog's Avatar
cheeky dog
Default Coilover expert garages? London?
my coilovers are making knocking noises and i need a garage who know their shit!
normally suspension issues are a troubleshooting job where you gotta keep changing things to get noises to stop!
im in west london so the closer the better!
cheers peoples
Old Nov 22, 2008 | 05:39 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
If they are knocking and its defo the coilover units causing it then it usually means they are shagged and need replacing/repairing!
Old Nov 22, 2008 | 05:49 PM
cheeky dog's Avatar
cheeky dog
the rear right is got a slight knocking when going over slow bumps. was told the pre loaders need adjusting. F**k knows what that means
the rear left is making a disgusting bang when the car goes over a bump where it sort of comes of the road
Old Nov 22, 2008 | 05:51 PM
big_wig_074's Avatar
big_wig_074
the spring might just not be seated correctly?jack up the car,locate the top of the spring correctly and lower it back down slowly,worth a try,my cossie used to do this sometimes if i jacked it up and didnt relocate springs correctly
Old Nov 22, 2008 | 05:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The preload is another name for the collar, it sounds as though the springs are either too short or you have the collar adjusted too low. Therefore raise the collar up, so it puts the spring under tension, as it sounds as though when you go over a bump, the spring is loose!
Old Nov 22, 2008 | 07:10 PM
If this is the case, you can get tiny poundage springs that go on the bottom just to take up slack when you jack up etc, but rate is so low doesn't do anything that you'd notice suspension wise.
Old Nov 22, 2008 | 07:27 PM
cheeky dog's Avatar
cheeky dog
thanx for the replies.
bit confused tho, what side are we talking about? making different noises on each side!
right sides got slight knocking
left side has got an almighty thud when the cars weight comes back down after a high bump! its like theres a heavy peice of metal in the boot flying up then slamming back down!
Old Nov 22, 2008 | 07:30 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
if when you jack it up, the springs are loose, you need to fit some helper springs!
Old Nov 22, 2008 | 07:41 PM
cheeky dog's Avatar
cheeky dog
im useless when it comes to mechanical stuff
prob need to take it to someone!!!
Old Nov 22, 2008 | 07:43 PM
Mike Rainbird
Caraholic
Because you have the collar wound down too low, so this is the springs jumping around!
Wind the collar back up, so the springs are properly preloaded like you have already been told to do by the garage that you took it to .
Old Nov 22, 2008 | 08:13 PM
cheeky dog's Avatar
cheeky dog
naa havn't taken it to any garage yet or i would have made em do it. explained the noises to someone and from what they thought thats what their conclusion was!
SOOOO does anyone know where can do this for me, im a mechanical looser!
Old Nov 22, 2008 | 08:31 PM
Mike Rainbird
Caraholic
Seriously it is a piece of piss - even your Mum could do it .
Jack the car up, so the weight is off the rear springs (use the rear diff to jack it up on). Place axle stands under the car for safety and then take the rear wheels off.
You will be confronted by this (this is the front of mine, but is just to show you the spring preload collar). All you have to do is wind this upwards (ignore the grease, I had a split gaitor ):
I would do it 1" to start with (both sides) and see how it goes.
You will probably notice on the nearside (the side closest to the path / hedges as you drive), the spring will be rubbing somewhere on the inner wing (you will see a shiney part where this has been happening). This is common to all Cosworths, and you need to beat the shit out of the inner wing where it rubs with a fuck-off big rubber hammer (be carefull not to hit the outer wing ) to give some clearance, as this will be the source of some of the noise . Also apply some grease or copper slip to this part of the spring if it is still skimming the inner wing, as this will stop it from squeaking .
Old Nov 22, 2008 | 09:54 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
whys it common on cossies mike ?
beef
Old Nov 22, 2008 | 11:34 PM
cheeky dog's Avatar
cheeky dog
ahh nice one, i'll have a go tomorrow
Old Nov 23, 2008 | 09:20 AM
Mike Rainbird
Caraholic
beef
Ford tolerances . They all need modding like this .
Old Nov 24, 2008 | 01:01 PM
cheeky dog's Avatar
cheeky dog
Seriously dumb question now but will winding the collar up raise the ride height? im going to run and hide....
Old Nov 24, 2008 | 04:49 PM
JTECH James
Passion for Fords!
yes
if you cant run it with the platforms touching the spring for some reason, ie your a chav....
you need helper springs to hold the main springs in place
Old Nov 24, 2008 | 04:58 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
beef
because they cowboys fitting them dont use the correct spacers on the rosejoints.
Old Nov 24, 2008 | 04:59 PM
Micky The Finn
Former Sponsor
to get round the cowboys incompatance?
Old Nov 24, 2008 | 05:16 PM
Mike Rainbird
Caraholic
Only the competition coil-overs have rose jointed ends .
Old Nov 24, 2008 | 06:06 PM
Micky The Finn
Former Sponsor
there is a lesson in that statement then mike.
so the cowboy statement still stands.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
DavidK
Sep 27, 2015 02:55 PM
