Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Escort TD to TDi
Old Nov 22, 2008 | 02:46 PM
55td's Avatar
55td
Default Escort TD to TDi
Hello - I have an Escort 55 TD van and want to fit the standard Ford intercooler to it and wondered if this was a straight fit without too much hassle!?? Can't see as the internals of the TD and Tdi engines are any different................
Old Nov 22, 2008 | 04:11 PM
bluescortcossie's Avatar
bluescortcossie
you can fit the intercooler straight to your TD but it wont make any noticeable difference to power
the get the power increase you need the TDI fuel pump and ideally the turbo as well
the internals are the same in the TD and TDI lump
Old Nov 22, 2008 | 04:53 PM
55td's Avatar
55td
So the actual turbo and fuel pump on the TDi lump are different then - can understand the pump, but the turbo??
Old Nov 22, 2008 | 05:06 PM
bluescortcossie
the turbos were different but its not essential as you can just increase the pressure of the TD turbo with a bleed valve or adjusting the actuator rod
chances are you wouldn't need to though , its the fuel pump that makes the power not the turbo , all the turbo does is force extra air into the engine to "dilute" the exhaust smoke
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
ST-170
Sep 4, 2015 11:02 AM
