cream in header tank!
Hi to all, i have just had a new zvh built all new gaskets rings pump ect ect... i have just found cream in my header tank and its only done 150 miles no wear near run in!
Any ideas!
maybe a dud head gasket!
Danny
Any ideas!
Danny
Depending on how well everything was washed/degreased, i.e the block etc, there may be some settlement of oil and shite in the water jackets within the block.
When you obviously get it up an running again you will end up with a small amount of oil/degeaser in your cooling system.
If this were the case, there shouldnt be much creamy stuff in there and a good flush out of the cooling system should get shot of it (if it is that of course!)
If it aint bad, give it a good clean out with lots of clean water and try again. If it doesnt work, it could be the h/gskt
i know the head wasn't brand new so it was acid dipped.... would acid have the same effect as oil?
I would have said probably not....???
The torque setttings should be:
Stage 1 = 20ft/lb (27.12Nm)
Stage 2 = 40ft/lb (54.23Nm)
Stage 3 = 60ft/lb (81.35Nm)
In the same sequence as normal (middle to outside)
now mate .i take it that its a 2ltr zvh ,if so you should of used a felpro 19 cvh head gasket mate.i think they are £40 from burton
cheers top man, am i right in thinking the APR ones are the same but just miss out the 90degrees bit as there non strech
yeah its a 2l ZVH... i have an cosmetic multi layer reusealbe one for a cvh on my oter engine witch is only done about 1000miles whould that fit a 2L
As for the gasket, you cannot use this as the piston bore on a 2.0l is much bigger than the standard CVH which is 79.96mm
ok thanks every one, you have all been very helpful. looks like i will be out there with a hose and torque wrench tomoz then
