MK3 TDCI electric power steering pump
I'm trying to adapt an electric PS pump to a project car. My goal is to replace the original mechanical power steering pump with the electric pump. With the new engine configuration, there isn't enough room for all the engine accessories.
Looking at the pump from above, one sees three different sets of connections. Two sockets have three connections and are positioned on opposite sidesr. The third socket is between the other two has only two connections. I'd like to know the function of each of these connections.
Maybe someone can say if this electric pump was available on non-diesel models?
The petrol models have them . The triple left side control both the side aim headlamps via a signal and ties in to steering limits for the ABS and esp. Same for the low level triple power circuit on the right side. The centre is POWER earth and Live running a require boost of 14 volts all but via running power circuit only engine running that is. The left from the front is earth and right is live. They feed into capacitator that store whacks of high voltage to drive a high end winding that sits below in a ally dry case and above sealed in the oil is resovoir is the direct linked pump sunk in a bath of oil . The top and bottom are seperat and the weaknesss in these pumps is that the motor locks at the lowwer bearing from ingress of moisture .
Forgot say the ingress of water destroys the circuit board in some way the motor is actually quite reliable but depends on the electronic circuit. The winding is fixed and the outer magnets are the spinninig item set on a rubber triple bed to stop vibration. These items are over 300 quid so get a good tested second hand unit.
hi chaps wonder if anyone can help me
got a 55 focus 1.6 which was front end damaged the pump was smashed so has been replaced with a used pump
fitted it no problem cars done about 8 mile and then stopped working so i put it down to a bad pump
fitted 2 more pump since everyone i fit has the same problem i have used the green recommended power steering fluid but its eating pumps for fun sounds really noisey after about 20 mins of driving like the pump is struggling anyone shead any light on it as im all out of ideas ?
wiring seems to be fine the big plugh has voltage not sure where to go with it
thx
blobby
thx
blobby
