Focus rs cosworth build 4x4 500+bhp, thinking about breaking?
Here's a few pictures of my focus i bought on ebay in january this year, it is a focus black so it came standard with black leather, my plans were to convert it to rwd and run around 330 bhp,
[IMG]http:/
I made a start to it in february stripping it to the bare shell.
it sat about all of march whilst i sourced some focus rs body panels.
some pictures of the parts i sourced before starting the build.
i also made a roll over jig before starting the build.
finally made a start on it in april, the rear quarters were the first thing to be changed.
next it was the new boot floor and rear coilover turrets.
after the boot floor was finished i went on to mount the rear end.
next it was the front crossmember and strut tops to change.
[IMG]http:/
are you using a sierra transmission tunnel or are you making your own? Lot of these conversions about now, just bought a 3 door focus n av got a damaged saph cossie so a recon ill be doin one, just waitin for insurance claim to be sorted.
Will be a real nice car and well finnished if your other conversions are anything to go off.
Did the spaceframed Mk1 fez sell, would of liked to have seen it finnished.
i've used the sierra tunnel and a section of the bulkhead.
alright barry,i bought all the bumpers etc from that saff off you
as above if any your other stuff is anything to go by this thing will be mint
davie told me he had a look at it when you bought the loom off him and said it was coming along well
good luck mate
good luck mate
should be finished by christmas, running a standard 2wd rear diff and a standard 4x4 front with a strengthning plate for now, still looking for a gearbox,
Well i have a bara box, gripper 71/2" rear and gripper front in a thick wall case for sale if i go ahead with breaking my car. Pity about the engine as mine is speced for over 500.
Full y built bara big tooth kit standard spec 1st but harder material, the rest are straight cut full bigtooth, uprated v/c aswell. Basicaly the same spec that was ran in the 600bhp reyland 3 door.
