series 1 brakes
Old Nov 8, 2008 | 06:45 PM
moesin2005's Avatar
moesin2005
Default series 1 brakes
any one know ant decent upgrades for the s1 brakes has 4x4 cos one with ferodo pads but still seem crap plus i want to keep the standered wheels
Old Nov 8, 2008 | 08:25 PM
studabear's Avatar
studabear
is everything else on the system working as it should be? new brake fluid makes a big diff!
braided hoses?
what makes you say they feel crap? pedal pressure, bite?
Old Nov 9, 2008 | 02:06 PM
moesin2005's Avatar
moesin2005
has new braided hoses new pads new cylinders new shoes new lines to rear its just the pedaL feels crap
Old Nov 9, 2008 | 02:11 PM
gus's Avatar
gus
some change to a s2 master cylinder
has a slightly bigger bore
Old Nov 9, 2008 | 03:19 PM
B16CVH's Avatar
B16CVH
Ive got the 4x4 calipers with 2wd discs on my S2 with braided lines and they work the tits, they only have cheap n cheerfull pads in to!, maybe the S2 master cyliner is the way to go?
Old Nov 9, 2008 | 03:57 PM
gus's Avatar
gus
yeah my cossie set up use to feel real good
Old Nov 9, 2008 | 04:22 PM
studabear's Avatar
studabear
sounds like there will be a simple solution to the prob, just hard to do over a pc
Old Nov 9, 2008 | 06:44 PM
moesin2005's Avatar
moesin2005
series 2 master cylinder what and use the t pieces in the lines how are they piped
Old Nov 9, 2008 | 06:54 PM
studabear's Avatar
studabear
cant see it to be the master cylinder thats causing this, I had a series 1 with standard brakes 8 years ago, and the brakes always seemed alrite.
Have you had it pressure bled?
Old Nov 9, 2008 | 08:41 PM
moesin2005's Avatar
moesin2005
hear about series 2 calipers on 2wd discs being better that cossie calipers anyone done this
Old Nov 9, 2008 | 09:22 PM
B16CVH's Avatar
B16CVH
The 4wd coz calipers have a bigger piston than the S2 ones so you have an increased clamping force.
I went from S2 Calipers to 4wd coz and they were noticebly better.
*Make sure your calipers aren`t seiezed in any way
*Use a good quality brake fluid
*Braided hoses all round
*Bleed the system properly
If all the above is done properly/ok then they should work fine to be honest.
Old Nov 10, 2008 | 05:34 PM
moesin2005's Avatar
moesin2005
how about pipeing for the series 2 master cylinder what goes where
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
