Is your car original, could have had the wiring for it removed.
as far as i'm aware is was an optional extra on all but the late 90 spec cars- if it wasn't fitted it won't have the wiring/plug etc as mine didn't.
If the car left the factory with one then there should be an extra bit of kit on the metering unit with a plug to which the fuel computer connects and runs from. I think it is by the metering head....???
There doesn't seem to be any wiring there. Was there a seperate wire running from the metering unit to the fuel computer or did the wiring run in the loom?
