which coilovers/suspension?
hi, i need to buy some new suspension but dont know wot to go for? on my escort cabby turbo, they must be height adjustables,i know gaz do them but who else makes height adjustables?avo?spax?
wot are you guys running and which do you prefer? and wot are they like? thanks for any help/advice ;0)
cant go wrong with koni's mate i have them of both my cars, had spax adjustable's once too also good
as for coil overs i don't personally have them but i'd go for gaz, good quality for price and there nice helpful people should you ever have a problem
Given the choice on a escort cab I would use Koni Adjustable and uprated springs of your choice with 25mm drop and poly bushed all round
These are not ride height adjustable but they give the right characteristics between handling and comfort.
The cab feels nervous on the back end with anything greater than a 25mm drop when braking at high speeds imho
Im now forced to use coilovers and have gaz due to rest of the suspension setup I am running, however it would not be my preferred choice due to the quality of the ride.
thanks for your replies guys ;0) i have used koni before and was very impressed they are definatly good, but i cant use them this time they must be height adjustables so looks like gaz or spax it is...
thanks,
jason.
thanks,
jason.
Ive got the GAZ coilovers and they are the tits, the car handles way better than with the Konis but the ride is less harsh than the Konis also, it doesnt break your spine everytime you hit a bump!
Do you run the GAZ on a cabriolet or on a hatch?, what settings and ride height do you have set, on my cabriolet the gaz ride feels a lot more unforgiving
They are fitted to a hatchback and if i remember correctly they are about 12 clicks from maximum and the arch to wheel clearence is about 25mm.
My car is fully rosejointed also so there are no cushioning rubber bushes anywhere but the shocks are still more forgiving than the konis were.
hiya, the reason is im fitting escort cosworth alloys on and ive had problems in the past with them catching the arches,the only way i got round it with the koni,s was to roll the arches and trim all the series one kit ;0( so this time i want height adjustables so i dont get any problems like last time,i dont want to start hacking the kit away. so i should be able to get it as low as poss without it catching..
Passionate about fords
all you guys using gaz coilovers, which ones have you got and what poundage springs etc are you using...........how do you find the handling over normal uprated shocks and springs ????.
dave.
dave.
iv had koni s avo coilovers on cars in the past they are both good dont get me wrong but i now have got gaz coilovers and they are by far the best so far.bit dear but you get what you pay 4 with suspension
if u opt for a cheaper product then stay away from hight ajustable only as ther is no point slammin your car on its arse if u cant stiffen it up aswell !!!
sound dan
sound dan
Last edited by lil dan B19 XRT; Nov 11, 2008 at 05:11 PM. Reason: 4got to say with the dampening settting puting it as hard as they go will stop it from catching the arches
They are the tits, come with 3 years warranty and you can re-build them also, they come with the correct springs for the car.
FRONT SPRINGS 9" x 300lbs, REAR 9" x 250lbs Part No. GZGHA312F
B16CVH......are the spring rates you mention above standard off the shelf rates as ive seen alot of places advertise much lesser spring rates, also with a much softer rate on the rear !!!!!!.
the reason i ask is ive got a brand new set of gaz ready to go on mine which i bought from a guy and they come with the same rated springs as you say and i was worried they might be really hard, how have you got them set up and how do you find them ????.
dave.
dave.
Well my car is running fully rosejointed front & rear so there are NO bushes anywhere on the car whatsoever.
The springs are off-the-shelf & the ride i will say is much better than the konis i had and are nowhere near as back breaking, they ride really well and the car handles like nothing else. You really lose all sense of speed as the car feels so stable through the bends, on many occasions ive looked at the speedo and ive been doin 90mph and it only feels like 50mph!
The car was setup at Zoo Motorsport as i fitted the shocks then got Brom to set all the camber, height etc....
You will not be dissapointed, mine have been on the car for 3+ years now
Yeah its got the lot, 6 link at the rear with bladed rollbar at the front, adj TCA`s and compression struts, its infinatley adjustable and drives like a dream!
http://i351.photobucket.com/albums/q...DSC00329-1.jpg
http://i351.photobucket.com/albums/q...DSC00327-1.jpg
http://i351.photobucket.com/albums/q...DSC00335-1.jpg
http://i351.photobucket.com/albums/q...DSC00334-1.jpg
that was with TCA`s so bout £900
