escort rs to be
hello i was wondering as i dont know everythink about engines.but to convert a xr3i efi to a rs turbo is the rs a cvh? and if so what would i have to do to run it?
also any one got any rs lumps for sale?
thanks lloyd
thanks lloyd
you would need to do a pin swap of a few wires at the ecu, change the engine to a turbo one as it runs low comp and has a oil return for the turbo, add a intercooler and turbo with a fiesta turbo ecu and map sensor and your away. i should have a lump for sale poss after the weekend, just need to confirm im getting my old engine back then the engine i was building will be up forsale, i have a ported efi rs turbo head just been fuly rebuilt including vavle seats recut, valves reface and lapped and sears worked on, and bottom end is stripped down, thermo stat, inlet, charge carrier all been sprayed satin black and looks smart, blocks sprayed silver too, pm me if interested.
Dr. Ickxs
Sep 15, 2015 10:15 PM
