RS turbo brake disc size?
Old Nov 6, 2008 | 05:18 AM
marv's Avatar
marv
Default RS turbo brake disc size?
Could someone please tell me what the diameter etc is of a standard front disc?
Thanks
Old Nov 6, 2008 | 07:06 AM
B16CVH's Avatar
B16CVH
260mm matey
Old Nov 6, 2008 | 07:45 AM
marv's Avatar
marv
Thanks mate,just wanted to double check
Old Aug 18, 2014 | 10:22 PM
Cameron's Avatar
Cameron
Default rs 1600i
I have a mk3 rs 1600i that had a break conversion before I had it. It has 280mm discs on the front that I think are cossys but with standard callipers with a bracket to make them fit (badly) could anybody tell me what callipers I would need to fit these discs and would da cossy callipers fit the bolt holes on my 1600i hubs thanks.
Old Aug 18, 2014 | 11:04 PM
kingbx95's Avatar
kingbx95
They sound like cossie 2wd discs and you need cossie 4x4 calipers to go with them. Should fit mk3 hubs aswell as mk4. Some people need some washers to sit the caliper correctly in line with the disc some don't seem to.
I didn't on mine. Think that's all that needs doing but it was a long time ago I did mine
Old Aug 19, 2014 | 08:31 AM
Cameron's Avatar
Cameron
Default D.A motorsport callipers
thanks for the reply I'm going to order a pair of D A motorsport cossie callipers now .
Old Aug 19, 2014 | 09:56 AM
kingbx95's Avatar
kingbx95
Not familiar with d.a. motor sport tbh.
The calipers you need are the single piston cossie calipers which I believe are off a 4x4 saph
Hope that helps
Old Aug 22, 2014 | 09:53 PM
mentalasanything's Avatar
mentalasanything
Hope that helps
Yep, 283mm disks are from a 2wd Cossie. You will need single piston 4x4 Cossie calipers (Escort or Sierra) or something that is designed to fit standard disks on a 4x4 Cossie.
Lee
jason_nike
Aug 18, 2019 10:53 AM
Matt Baxter
Sep 16, 2015 08:30 PM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
