Cossie Parts
2wd Mongoose Exhaust mint apart from oil staining, done 900 miles, has a M18 Boss for Wide Band Lamba and a M12 Boss for Closed Loop in down pipe, mint condition full system, cost me £350 sell £170
Motorsport Lead Set £40 (dizzy not coil pack)
Crank Pulley £40
2wd Rear beam minus diff, polybushed with 4x4 ARB, Arms and Driveshafts, (no calipers) £80
Rad and Fan set no leaks excellent condition £50
Front Powdercoated ARB £20
Spec R cam belt cover £80
Spec R Power Steering Tank £75
Spec R Breather Group A breather with catch tank and seperator, inc hoses £170
Spec R Fuse box cover £35
Spec R Battery Cover £20
Spec R Turbo Damper £60
All spec R items as job lot £390 delivered
Black under headlamp strip without the wiper cut outs £15 in black and mint
2wd Fly Wheel £30
2wd Sump £40 (with oil return)
Crank Pulley £40
2wd Fly Wheel £30
155lee
Sep 6, 2016 11:10 AM
