pistons
hi guys, just out of interest, is it necessary when rebuilding a YB to used pistons
with the valve cut outs, i know cut outs would be needed when runnind big cams etc
but using std cams with a new rebuilt engine should one be using pistons with cut outs???
cheers.........
cheers.........
I would do this because even with totally standard engines sometimes the valves hit the pistons.
most cossie's have had valve to piston contact - but this is normally due to neglect rather than anything else
if you;re going for big power than yes i would get them; if its standard then i wouldnt bother
As said if keeping std cams etc then not needed, thoyugh clipping can still occur very gently, especially as valve springs get tired.
I would personally though just for peace of mind, a good safeguard for future mods as well, as most people will want more power at some point!!.
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
