removing gear box on 4x4
Old Nov 2, 2008 | 05:30 PM
mattyonline's Avatar
mattyonline
Default removing gear box on 4x4
hi guys was helping removing the engine from me m8ts saph 4x4 and i was unable to remove the gear leaver from the gearbox so that we can remove the gearbox to get the engine out, we had no clearance to remove the engine while the gearbox in place anybody got anyideas on how i can remove the gear leaver please ?
Old Nov 2, 2008 | 06:07 PM
dojj's Avatar
dojj
Resident Wrestling Legend
remove the electric window switch
remove the surround
lift up the rubber gaitors aruond it
unscrew the 4 philips screws
you will see 2 roll pins
you need to knock out one of these pics and then pull the skitcj off the end of the selector
it may be tight
Old Nov 2, 2008 | 06:13 PM
mattyonline
dojj i didnt see any roll pins just a plastic sorround with a circlip in the middle any ideas
CLIVE
Oct 2, 2015 12:58 PM
matman
Sep 9, 2015 05:45 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
