Headlights S2
Old Oct 30, 2008 | 06:13 PM
Rs-Simon's Avatar
Rs-Simon
Default Headlights S2
Hi. My S2 has developed a problem with the lights, dip beam both sides work (1st click). Main beam both sides (2nd click), dont work and the dip beams go out. High beam works. Swapped the 2 little brown relays round and still the same. Also I swapped the light stalk over, changed the bulbs for known working ones. Still the same.
Any help will be much appreciated thanks.
Old Oct 30, 2008 | 07:01 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Probably an earthing problem mate, escorts are notorious for em!
Old Oct 31, 2008 | 08:07 PM
rst1990's Avatar
rst1990
i had the same prob turned out to be a wiring fault under the fuse box ie the connector had been accidently pulled off. hope this helps.
Old Oct 31, 2008 | 08:16 PM
bezo's Avatar
bezo
powered by K26
dude it aint the brown relays, its the white ones.
having the same prob with the van at the mo.
Old Oct 31, 2008 | 09:29 PM
Brian's Avatar
Brian
I had this prob on my old Series 2 it was the white relays need to take them out and clean the contacts and then get a small screw driver and bend the connections in the fuse box a little bit.
What i done on my old Series 2 was lifted the fuse box then re run the wires to the white relays to in side the car under the dash never had any probs after
Brian
Old Nov 1, 2008 | 12:58 PM
Rs-Simon's Avatar
Rs-Simon
Thanks for all your help.
Old Nov 1, 2008 | 01:49 PM
B16CVH's Avatar
B16CVH
I had this problem many moons ago only mine went out at about 90mph!
There was a faint smell of burning plastic, when i investigated, the contacts in the fuse box had opened up casing them to arc between the spades on the white relays causing heat build up.
In the end, i had to lift out the fuse box and put new spade connectors on a few of the wires as the original connecters were FUBAR`d, was not an easy task! Been ok since tho!
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
mondeomark
Sep 28, 2015 06:28 AM
Kam B
Sep 24, 2015 10:40 AM
