Fuses on the Battery
Old Oct 30, 2008 | 10:50 AM
G1EN's Avatar
G1EN
Default Fuses on the Battery
Does anybody know what the A B D E F G fuses on the Battery in the small black box are?
Old Oct 30, 2008 | 11:31 AM
JHS's Avatar
JHS
Some are for radiator fans, some are for power supply to fuse box. Not sure if thats all of them though.
Old Oct 30, 2008 | 11:34 AM
G1EN's Avatar
G1EN
Hmmmmm that could answer a problem, my fast speed setting in the fans isnt kicking in, so is that one them fuses..
be usefull if someone has an exact list of them.
Old Oct 30, 2008 | 10:15 PM
MarkN's Avatar
MarkN
The handbook says what those fuses do.
IIRC three are main fusebox feeds (ABC), one is for the heated windscreen, and one is for the ABS.
I don't think the fan is feed directly from here. In any case if it was and the fuse is blown it wouldn't work at all.
Old Oct 31, 2008 | 09:56 AM
fish99's Avatar
fish99
Have you checked the fan switch at the bottom of the radiator. I know my one the multi plug broke and I had to hard wire the switch. Just a thought.
I would get a bit of wire and bridge the switch first.
Old Oct 31, 2008 | 10:27 AM
G1EN's Avatar
G1EN
I put a New Rad Switch in and still no good. So it could be the multi plug as i bridged the switch and the fast speed seeting worked, it just dont kick in when it hits its required Temp to come on.
Old Oct 31, 2008 | 10:32 AM
G1EN's Avatar
G1EN
No Handbook LOL
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
