MK6 pedal conversion?
Old Oct 27, 2008 | 07:46 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default MK6 pedal conversion?
as above i have a helix paddle clutch, and would like a higher clutch bite, would this conversion work with the clutch on my s2
Old Oct 27, 2008 | 07:54 PM
babscossie's Avatar
babscossie
do you mean the manual adjusting pedal.
if so, yes it will work on your s2 and is a very good conversion.
Old Oct 27, 2008 | 07:57 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
yea the manual adjustable, how does it work thought it would only work on the ap clutches?
Old Oct 27, 2008 | 08:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It just gives you a bigger clutch quadrant (for more travel), and adjustable pedal height.
Old Oct 27, 2008 | 08:12 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
so i can adjust where the clutch bites?
Old Oct 27, 2008 | 08:16 PM
babscossie's Avatar
babscossie
correct
Old Oct 27, 2008 | 08:30 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
looks like ill be gettin this, as my clutch bites basically on the floor its horrible really. are they easy to fit?
Old Oct 27, 2008 | 08:35 PM
babscossie's Avatar
babscossie
its not a hard job but is very awkward and fiddley (sp)
look at the set up before you take it apart and make a note of where all the spacers and horse shoe clips go.
Old Oct 27, 2008 | 08:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah it is VERY fiddly, had mine out the other day to change the brake pedal plastic washers!
In fact you may aswell do that whilst your there, they are about 20p each and will save you doing it all again if your pedal starts flapping around
Bryan_RST's Avatar
Bryan_RST
Smile metal quadrant
if i were you i would get a metal quadrant because the plactic one brakes easy i got my metal one off here someone mate started to make them and was selling them on here
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
