spark gaps
Old Oct 27, 2008 | 06:41 PM
cossie0_4's Avatar
cossie0_4
Default spark gaps
ive ordered some 071 for my saph its running light blues/t34 28psi group a coil what is the recomended gap for plugs that you use cheers
Old Oct 27, 2008 | 06:48 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I would've thought 0.7mm would be OK for that...wait for a few more replies though
Old Oct 27, 2008 | 07:10 PM
cossie604's Avatar
cossie604
iirc these plugs are better at .6mm with dizzy set-up and the gap is measured with feeler at 45degree angle. larger gap with coil conversion mind.
Old Oct 27, 2008 | 07:24 PM
I used 0.65mm on mine with group a coil, but 0.5mm on my coilpack, as higher boost.
Old Oct 27, 2008 | 07:32 PM
KSA-Cossie's Avatar
KSA-Cossie
0.65mm on coil
Old Oct 27, 2008 | 07:33 PM
cossie0_4's Avatar
cossie0_4
thanks for the replies hopefully here 2morow and get them set and hopefully misfire will be cured cheers
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
pabloXR
Sep 21, 2015 12:42 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
