Cam timing
Old Nov 13, 2004 | 08:41 PM
Paul_RS's Avatar
Paul_RS
Default Cam timing
how much would it affect my car if the cam timing is slighty out? I've a piper 285t2 cam and i'm not too sure if its timed exactly right.
Old Nov 13, 2004 | 09:00 PM
MK5RST's Avatar
MK5RST
Im new to the turbo scene but through experience i know that if the cam timing is a one or two degrees out its just a power loss but any more could result in overheating or even failuer
Old Nov 16, 2004 | 01:36 PM
sufsRS's Avatar
sufsRS
its nt good if its out, your engine will not run right ay all, performance goes down, fuel consumption is higher, engine speeds are affected. The reason i know is when ibought my turbo i knew it wasnt running right at all, then i bought a new timing belt kit including the tensioner now it runs spot on no problems at all.
Old Nov 16, 2004 | 10:52 PM
JaysS2TURBS's Avatar
JaysS2TURBS
Do you have the Piper adjustable vernier pulley if not get one so you can adjust the timing correctly and obtain the best performace from your cam ive got one on mine. They cost around 80 quid. If the timing is slightly out it will probaly run a bit rough or possibly could cause some damage to the engine. All the best
Old Nov 17, 2004 | 10:05 AM
sime73's Avatar
sime73
yeah u deffo need a vernier pulley for these engines to get top performance
RUBY123
Oct 22, 2023 12:04 PM
Danielbetty
Oct 3, 2015 06:01 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
