what top hats to use on Billstein 909 front coilovers
Old Oct 23, 2008 | 06:55 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default what top hats to use on Billstein 909 front coilovers
Do you use the std cosworth tops or do you need special items here are my coilovers.
Old Oct 23, 2008 | 08:52 PM
Roosie's Avatar
Roosie
up
Old Oct 23, 2008 | 09:11 PM
jon@work's Avatar
jon@work
Don't use standard top mounts, it'd be a bit of a waste (if they fit, which I doubt).
You could use eccentric or concentric Compbrake/TAS style top mounts, or Gp N, Gp A, or WRC top mounts (with suitable spacers if the top mount bearing is too big).
The choice depends on budget, car use, and the rest of your front suspension specification.
Old Oct 23, 2008 | 10:09 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
the dampers in the picture shown have the tophats in the correct place,are you getting confused with what a top hat is?
Old Oct 23, 2008 | 10:27 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Do you mean top mounts perphaps? I have the 909 top mounts using a polybush in the strut top. Should these be solid mounted?
Old Oct 23, 2008 | 10:28 PM
Roosie's Avatar
Roosie
well the top part of the damper.so what do i need to make these fit my cossie
Old Oct 23, 2008 | 10:59 PM
Micky The Finn
Former Sponsor
well in answer to your original question the top hats to use are the exact top hats that are fitted in your picture,nothing more,nothing less.
Old Oct 24, 2008 | 07:08 AM
Roosie's Avatar
Roosie
so i can use these shocks straight into my cossie with a std type turret at top?
Old Oct 24, 2008 | 08:12 AM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
I've just got these in stock if your are interested
https://passionford.com/forum/sin-bin/264204-cosworth-rose-jointed-top-mounts-group-buy-now-with-pics-fitted.html
they come with the spacers etc.
This style of top mount is used on Group N cars I think. It used the std bush and requires no drilling.
PM me if your interested as there are a couple in stock that I could do for the group buy price.
Old Oct 24, 2008 | 08:15 AM
Tony Ryan's Avatar
Tony Ryan
No ,
jon gave the correct reply , tim was taking the piss but was correct in as much as the 1mm tube spacer on the top of your dampers are referred to as "top hats " they site the damper inside the bearing of the top mounts already mentioned . You may have a few issues making the little roadcar bearing and rubber mounts fit these .
Old Oct 24, 2008 | 02:50 PM
BRIGSPORT's Avatar
BRIGSPORT
https://passionford.com/forum/showthread.php?t=264204
They're like mine, only mine are black with a 909 part number. They don't fit very well with a standard bush though. Perphaps i should trim my bush?
Old Oct 24, 2008 | 04:09 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I have a pair of eccentric top mounts in stock .
Old Oct 24, 2008 | 06:14 PM
jon@work's Avatar
jon@work
are you using Escos bushes ?
Old Oct 24, 2008 | 06:17 PM
BRIGSPORT's Avatar
BRIGSPORT
No, i am using xr4x4 poly bushes, and it is the type that sits in the strut top on the shell. I seem to remember that when i took them off the donor rally car, the top bit of the bush was missing, hence i think i need to trim the top lip off my bush. Any ideas?
Old Oct 24, 2008 | 06:32 PM
jon@work's Avatar
jon@work
When I got my top mounts, I was told to buy standard Escos bushes, and boil them to help fitting (without being trimmed).
The old bushes that came with the mounts had been trimmed slightly, but I remember Brom told me that when he and SeanB fitted some to Seans' car, they were "slightly awkward" to fit with untrimmed Escos bushes.
Old Oct 24, 2008 | 07:00 PM
Roosie's Avatar
Roosie
looks like my gravel spec front billies are for sale then lol
Old Oct 25, 2008 | 11:51 AM
NUTS RuS's Avatar
NUTS RuS
Just fit them with 25mm bearing eccentric top mounts if its going to be a track car.
Plenty in stock
Old Oct 25, 2008 | 01:33 PM
Micky The Finn
Former Sponsor
i wasnt taking the piss tony,he asked about top hats,and i gave the correct answer.
now it seems he has called them the wrong thing,the top hat is the spacer/retaining ring as shown in your picture,you actually meant strut tops then?if so tony is correct.
and tony,in stock next to my brake bells? iam running out of time,car is out nextweekend!
Old Oct 25, 2008 | 02:14 PM
NUTS RuS's Avatar
NUTS RuS
Bells in stock Tim yes, but Im still awaiting your caliper details to measure up against the brackets here
Im passing Chris T's next week to pick up his bells
Im sure I called and left a message - maybe it was Chris's phone sorry
jessie_rs
11
Jun 3, 2019 04:57 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
sierra cossie
Aug 7, 2015 12:17 AM
