Alternator Wiring
Old Oct 22, 2008 | 02:29 PM
Bens2rs's Avatar
Bens2rs
Default Alternator Wiring
Can anyone help, im changing my alternator and have found that the new alternator hasnt got the push type connector instead it has threaded studs for eyelet type connectors can any tell me what colour wire is which???
Cheers Ben
Old Oct 22, 2008 | 02:40 PM
nigel b's Avatar
nigel b
blue wire,the small one goes back to the dash
the other 2 on the large connector go to the starter motor
Old Oct 23, 2008 | 10:25 AM
Bens2rs's Avatar
Bens2rs
nice one ill try it
Old Oct 23, 2008 | 12:41 PM
iansoutham's Avatar
iansoutham
OCD Victim
small blue wire goes to D+ on the alternator, 2 red wired connected together go to the B+ terminal.
W terminal is a single-phase output and not used normally.
The alternator fitted to your vehicle would probably have been a 45/55A, and the new one will be a 70A or greater. Make sure your red cables are up to the job or it could all end very warm and toasty if you know what I mean.....
Old Oct 24, 2008 | 10:06 AM
Bens2rs's Avatar
Bens2rs
will make sure its sound before i connect everythin mate cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
