Cosworth rear beam
Old Oct 22, 2008 | 12:10 PM
capri280's Avatar
capri280
Default Cosworth rear beam
is an escort cosworth rear beam the same as a sierra one
Old Oct 22, 2008 | 12:14 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Same as a 4x4 sierra rear beam IIRC.
Dan
Old Oct 22, 2008 | 12:50 PM
capri280's Avatar
capri280
Default beams
so escort cosworth and the 4x4 beam are the same and the 2wd one is different
am i right
Old Oct 22, 2008 | 04:11 PM
dazzle740's Avatar
dazzle740
escort and the 4x4 are the same but the 2wd is different due to using bigger diff, or so i believe
Old Oct 22, 2008 | 10:05 PM
AndyPen's Avatar
AndyPen
2wd has a 7.5 diff n needs a bigger carrier / mounting for it in the middle
Oct 9, 2015 07:38 PM
Bosch
Aug 23, 2015 12:31 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
