4x4 rear disc backing plates still available???
After some new backing plates that go behind the rear discs, although I have a sneaky suspicion that these are no longer available new, is that correct???
Also i believe the 2WD ones are different?
2wd ones should be the same
and, based on that logic, so should the ones for the scorpio frog faced 24V versions
these stopped production in 1998 or so, so they should be about somewhere
one more thing, the normal sierra backing plates fit as well, even though they are much smaller and so might have some sort of effect on the cooling side of things
Cool, didn't know the 2WD ones fitted, as all the ones on ebay just list 2WD only and not 4x4, i heard the Mk3 scorpio ones fitted somewhere else so that's good to know someone else agrees!
they are the same hub carriers on the 2 and 4wd cars and the granada 24V's use the same hubs as well
the scorpio also uses virtually the same hub carriers but with a different offset to the calipers and discs
how are they different?
can you put up some pics to show us what's changed between the 2?
and, if they different, does that mean they won't fit? or is it just that they are different but will fit?
why's that then when the vented bit of the disc is added to the outer part of the disc rather than the inner part?
just trying to get my head around some of this confusion, i've got a set of really crumbly back plates at home for the 4wd cos so i'll see if i can get some measurements from them
jason_nike
Aug 18, 2019 10:53 AM
james kiely
Aug 28, 2015 08:58 PM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
