cvh turbo into mk5 escort
whats needed? the mk5 has power steering etc.... i will be going for mfi unless i find someone selling cossie managment, but i need to know what else i need to complete the conversion, can i use the same part of the loom that the xr2 boys use to convert to turbo? what about power steering pump? intercooler, rad etc??????? and do the hatchback springs fit the estate? any help is much appriciated
Jt
Jt
for this you will need the whole mfi loom engine rad intercooler drivshafts intercooler turbo and u will need to swop everything and connect the mk4 wires to the mk5 dash
the xr2 lads use the efi systems as the xr2i and rs aint too different summit bout swopping pins on the ecu other than that its a straight swop
hope this helps
hope this helps
Matt Baxter
Sep 16, 2015 08:30 PM
