ABS problem
Old Oct 19, 2008 | 07:24 PM
costina's Avatar
costina
Live long and prosper!!
Default ABS problem
Abs pulses just before you stop,no light on and checked front sensors
But the rear discs are taking for ever to bed infitted new front and rears same time
Could the rear sensors be the problem ?
Any ideas or suggestions please
BTW it has a 350mm on the front and has started since fitting them
Thanks
Paul
Old Oct 19, 2008 | 07:30 PM
ECU Monitor Enthusiast
Sure you have enough fluid in the resovoir ??
I had this, and it was where the fluid was low and the low level sensor was tripping as the fluid sloshed around.
Old Oct 19, 2008 | 07:37 PM
costina's Avatar
costina
Think so Simon could well be too much trouble is do you check while running (PUMP) or not
BTW i still hav'nt sorted that other issue out i PM'd you about done what you suggested still no joy( 4 lugs )
Paul
Old Oct 19, 2008 | 07:41 PM
Level checked with ignition off after pumping the brakes pressure away.
As for the other issue, give Spencer a call or PM .. :0
Old Oct 19, 2008 | 07:44 PM
costina's Avatar
costina
Cheers Simon will have a look and i could do with havin a chat with Spence
Paul
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
