t25 throttle body
Old Oct 17, 2008 | 05:14 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
Default t25 throttle body
hi
can I put a t25 throttle body on my t34 escos? got a complete t25 intake manifold and want to know what can't be used.
Thanks
Old Oct 17, 2008 | 05:28 PM
robbieg's Avatar
robbieg
Dependent on what management you are using.If using the standard P8 you will have to make an adaptor plate to fit the weber TPS(eeciv TPS won't work on weber management)Also the iscv won't work on weber management(car will still run though).Regards Robbie
Old Oct 17, 2008 | 05:43 PM
tore_tj's Avatar
tore_tj
Cossie Paranoia
ok. is there an advantage running it or is the standard t34 just as good? I can smell a throttle body for sale..
Old Oct 25, 2008 | 05:41 PM
mikedaf2's Avatar
mikedaf2
i would use all of it as they flow more air and from memory if you rewire the tps it will work.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
