comparison with st170 and focus rs head
Old Oct 17, 2008 | 12:27 PM
scotty86d's Avatar
scotty86d
Default comparison with st170 and focus rs head
is the focus rs head different to the st170 one in terms of ports and valve sizes?
Old Oct 17, 2008 | 02:46 PM
testastretta999's Avatar
testastretta999
Default head
I think st170 has bigger valves, not sure on porting. Does'nt st have variable cam timing?
Best head for the money imho for zetec is Ford Racing one from states.
Old Oct 17, 2008 | 02:48 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Completely different heads. The only thing remotely similar is the size and shape of the exhaust ports.
Old Oct 19, 2008 | 02:35 PM
R5AAL's Avatar
R5AAL
St has variable cam timing,totally differnt units.
FRS has sodium filled valves though lol
Old Oct 20, 2008 | 01:52 AM
scotty86d's Avatar
scotty86d
Originally Posted by R5AAL
St has variable cam timing,totally differnt units.- knew that bit
FRS has sodium filled valves though lol-good to know, can you get aftermarket ones for the st head or will they fit straight into the st head
so the st170 head is better flowing?or just has larger inlet ports
Old Nov 2, 2008 | 10:01 PM
pdfbt40's Avatar
pdfbt40
If that was true then you wouldn't be able to easily swap a ST170 head onto a 'blacktop' engine.
The detail of the valves, cams, etc. are different as it has high lift cams and, as mentioned, the VVT on the inlet cam. The inlet port is bigger and flows a lot better than the shape of the standard/RS head, but the valve sizes (but not stem lengths), angles, cam centre lines, etc, etc. are the same as the standard/RS blacktop.
Oh, and even the head chamber volume is the same......
Martin
Old Nov 3, 2008 | 05:09 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Martin
Okay, to clarify my comment to fight off the pedants.. I was referring to the flow characteristics of the head as that is what is important in head related discussions.. I think you'll find the inlet valves are a different size too.. Try putting both heads side by side and doing a proper comparison
Old Nov 3, 2008 | 07:19 AM
pdfbt40's Avatar
pdfbt40
Which is exactly what I did over 3 years ago.....
Your forgetting that the valve sizes were increased from the Silver top in the Black top engine. I apologise, the ST170 inlet valve is 0.5mm bigger diameter.
As for being pedantic, not being remotely similar, I think is applicable to a comparison of CVH to Zetec head, not the subtle differences of the St170 one. Which as I said is a not too difficult swap. Many of the parts can also be used in a standard head. As an example, the solid top cam followers are a far cheaper way to go with high lift valves, than after market ones. Making it all work properly, as with anything, is another matter.
Martin
Old Nov 8, 2008 | 11:29 AM
crazycage's Avatar
crazycage
here's a little comparison for you . the first pic is a black top head with a deep reach 19mm socket in the inlet port and the second pic is a st170 head with the same 19mm socket in the inlet port . hope this helps clear things up a bit
Old Nov 8, 2008 | 08:09 PM
pdfbt40's Avatar
pdfbt40
Details, details. Its hardly "completely different".
The main reason you can do that is because the dividing wall between the valve throats is much shorter on the ST170, not the extra 5mm height of the port at the manifold face.
Martin
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
gavt123
Sep 5, 2015 10:03 AM
Fordmad!
Sep 4, 2015 01:42 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
