Escos - junkie clear out
Almost there!
several odd little bits that may be of use to someone, rather than it all sat in a box in the workshop.
BT Wing Mirrors - £15
Rear Seat carpets - the carpets that go on the back of them (boot sides) - £10
Door Pad sections (the padded soft bit at the back of the armrest area on the door cards) - £10
A pillar trims (both sides) - £10
2 x stainless heat shields (AS Autos, to shape over the air filter, both unused) - £10 ea
centre consul/armrest lid (the fold up lid, in the grey suede effect material) - £10
Standard header tank - £10
2x standard Escos stereo amplifiers (the ones that bolt to the bulkhead under the dash) - £10 ea
Sill trims (the plastic trims that come along the sill and up to the base of the dash, both sides) - £10
Fuel Tank straps (covered in alot of grime and dirt and surface rust, would be fine with a blast and powdercoat session) - £10
Nothings expensive - just clearing out whats not needed for a few pennies in the pocket.
If the little clips are still intact and they arn't scuffed then i'll have these off you buddy
Almost there!
ill PM a pic over to you tomorow afternoon Dave, Just dont hold me to any time scales incase i dont send them over until late at night
Take it your at work then Dave?
Kelv - what's the header tank like?
Also if Monster wants those trims and we can meet before the AGM I will gladly pick them up and drop them off to him - as long as that's ok with the both of you
Almost there!
Rich - it will have been to the ring etc way before Lemans mate
Ben, pics will be popped over later for you, ive got to photo all the bits when i get to the workshop.
but yeah thats cool with me for the bits for Dave.
