Is The 2wd Saff Floorpan The Same As 4x4 ?
As Above , I Have Complete Running Gear For A 4x4 And I Am Possibly Looking At A 2wd Saff Shell The Weekend ,, Is There And Difference Or Mods That Need To Be Done To Fit 4x4 ??
Thanks In Advance
Thanks In Advance
the tunnel is differant but it can be opened up a bit to fit the 4x4 box,
the front chassis legs are also slightly differant, the 4x4 has small arches in them to allow clearance for the drive shafts, these are only required if you lower it a fair bit
truffleshuffle
Sep 10, 2015 09:35 PM
